Best standby switch wiring in 2204
Hello, in my amp i have
bridge rectifier - filter cap - standby switch - ht fuse - choke and ot center tap.
But i also see in other layouts
Bridge rectifier - standby switch - filter cap - ht fuse - choke and ot center tap.
The filter cap is after the switch not before like mine.
What do you prefer?
My amp when playing at high volume and high gain will squeal for two seconds when i put it into standby. I was wondering if it was because of my standby switch configuration. It wont do this at moderate volumes.
What do you prefer?
Re: Best standby switch wiring in 2204
The best plan is not to use a standby switch at all.
frankdrebin
you can wire the standby to the screen grid line only,that is much less stressful on the contacts,Peavey used to do that
I would use a DPST switch between the PT and diodes just like Marshall did.
https://el34world.com/charts/Schematics ... w_2204.pdf
...Steve
It's a question of objectives - what do you want a standby for? Here are some possible reasons.
1) just because this amp (or other amps historically) have one
2) to mute the amp but be able to have it fire right up instead of waiting for the tubes to warm up for short quiet periods
3) to save wear and tear on the tubes from multiple heat/cool cycles
4) some other reason of your own? Stopping the squealing is a good one.
For reasons one through three, you get just as good a result from rewiring the standby switch so it mutes the input to the power amp. It's safe and effective.
"For every complex problem there is an answer that is clear, simple, and wrong"
H. L. Mencken
H. L. Mencken
I have been using this setup a lot and have not experienced any issues.
bridge rectifier - filter cap - standby switch - choke and ot center tap.
2R also does similar setup.
Cheers
Guy
Cheers
Guy
Just to note that the 2204 has a 2 phase rectification.
I don't think I've ever seen a 2204 with a bridge rectifier.
...Steve
No sorry, i messed that up. Its just the normal 2204 2 phase in this amp.
I think will try the normal marshall style of standby as sluckey suggested, just got to order a switch.
Thanks all!
Thanks all!
I installed the new switch but im getting a short loud electrical type hum when i take the amp off of standby. Only lasts about a second or so. Maybe its the in rush to the first filter cap? Its louder at 120vac than at 90vac. The filter caps are only a year old.
The standby switch is now wired like a normal marshall 2204. The DPST is between the PT and the diodes.
Is the bias circuit energised whilst the amp is in standby mode?
I dunno, Marshall were wiring their 50 watters like that for maybe a decade, including the first 2 iterations of the 2204 (JMP era) https://el34world.com/charts/Schematics ... l_2204.pdf
