New Amp Build
Guitarxtc
New Amp Build
Post by Guitarxtc »
Here is my new amp build : 100w 4xel34,6x12ax7, 3 channel, high end caps,C-core transformers and point to point wiring.
Biggest challenge was this time to make PTP wiring in small chassis(470x195x60mm).
I am still working on switching, but end result will be with headshell (Italian poplar) only 11.5 kg for full 100w head :)
Re: New Amp Build
Wow! That's full power OCD, and I salute you!
alnight
Re: New Amp Build
Post by alnight »
That is an impressive piece of work there sir. What do you think of those Jupiter caps? I have yet to try any of those, but I amp curious.
TUBEDUDE
Re: New Amp Build
Post by TUBEDUDE »
Cause they're spendy AF.
romberg
Re: New Amp Build
Post by romberg »
Very nice work! I'd love to see a schematic or just a description of the topology of each of your three channels. Is one of the channels a gain stage added? I'm kinda guessing based on the controls.
Mike
Guitarxtc
Re: New Amp Build
Post by Guitarxtc »
TUBEDUDE wrote: ↑Thu Dec 14, 2023 3:23 am Cause they're spendy AF.
Not really expensive(about 300eur per piece),in EU Mercury Magnetics cost 50% more.
jabguit
Re: New Amp Build
Post by jabguit »
Guitarxtc wrote: ↑Thu Dec 14, 2023 11:42 am
in the US Mercury cost 50%+ more
Jack Briggs
Briggs Guitars
Guitarxtc
Re: New Amp Build
Post by Guitarxtc »
romberg wrote: ↑Thu Dec 14, 2023 3:44 am Very nice work! I'd love to see a schematic or just a description of the topology of each of your three channels. Is one of the channels a gain stage added? I'm kinda guessing based on the controls.
Mike
I don't have schematic, started from zero. 1-Clean channel ,2-drive channel-First stage parallel-2-3-4-and cf, 3-channel-first parallel-2-3-4 plate driven and different tone stack
bepone
Re: New Amp Build
Post by bepone »
it is very expensive build, free flow build i like that..with all the expensive parts from HiFi collective..IMO maybe no need to go this route, i discovered that some cheap parts works better (EJ parts :mrgreen: ) .. been there..
also i never liked exposed terminals on Lundahl , service guy can be electrocuted in a second..
interested to see the results/possible problems..
Guitarxtc
Re: New Amp Build
Post by Guitarxtc »
bepone wrote: ↑Thu Dec 14, 2023 11:56 am it is very expensive build, free flow build i like that..with all the expensive parts from HiFi collective..IMO maybe no need to go this route, i discovered that some cheap parts works better (EJ parts :mrgreen: ) .. been there..
Lundahl are there only for weight saving :)
bepone
Re: New Amp Build
Post by bepone »
Guitarxtc wrote: ↑Thu Dec 14, 2023 12:06 pm Lundahl are there only for weight saving :)
and price increase :mrgreen: you can use torroids it is the same weight (light) and 5* cheaper (using magnetic flux of 1.5T like here (around) to have low number of turns and smaller core :wink:
possible problem in using high saturation core like here /discovered in the past / that attack on the note is very fast, so not good for some types of music..for metal is ok
Guitarxtc
Re: New Amp Build
Post by Guitarxtc »
bepone wrote: ↑Thu Dec 14, 2023 12:51 pm
I will look into Toroidal, maybe try hybrid rectifier: tube and SS at the same time ?
Sad si mi dao zanimaciju :mrgreen:
TUBEDUDE
Re: New Amp Build
Post by TUBEDUDE »
jabguit wrote: ↑Thu Dec 14, 2023 11:45 am
Yeah, we have different definitions of expensive.
maxkracht
Re: New Amp Build
Post by maxkracht »
When I'm feeling fancy I spring for the 1000v Panasonics. :D Very nice looking build!
Raja_Kentut
Re: New Amp Build
Post by Raja_Kentut »
great craftsmanship!
You seem to be from Europe, like me, can you tell me the source for the elco holders ?
Nothing is better than an unexpected discovery that brings you happiness!
