2025 Monkeymatic Palisade 30w (Liverpool, non traditional)
I have had a Heyboer transformer set in the closet for a while, and an old chassis from RJ. Based on the success of my 15w non-traditional Liverpool, I'm building a 30w version, with a LND150 input gain stage, and a PI "soak" master volume (50K pot in series with 1K PI cathode resistor). This build also qualifies as a "beaks and feet" build, meaning only parts I have on hand.
maxkracht
Re: 2025 Monkeymatic Palisade 30w (Liverpool, non traditional)
Post by maxkracht »
Does it still count as "beaks and feet" if you have been collecting bird parts for years? :D
Where did you get those plastic grommets? Looks like they would be handy for repairs on old amps that didn't come with any but clearly should have.
maxkracht wrote: Mon Apr 07, 2025 8:20 pmWhere did you get those plastic grommets?
Grommet Strips Molded. I think I got these from mcmaster.com. Heat them until flexible. I think 0.75" diameter holes are about as small as practical.
maxkracht
Post by maxkracht »
Thanks!
Layout. [updated 17apr2025]
Progress post.
solderhead
Post by solderhead »
I like those tube sockets. Where to source them?
Better tone through mathematics.
solderhead wrote: Mon Apr 14, 2025 2:05 am I like those tube sockets. Where to source them?
They are standard tube sockets, with the addition of Lou's PCBs: https://luigiretro.com
All done. Good sound, but brutally loud out of the gate; no bedroom manners. I already dump half the gain after the second triode. Also lowered NFB resistor from 100K to 50K. Will swap in 12AT7s tomorrow, for lower gain. Otherwise, very good!
I was going to use a single cathode resistor for the power tubes, and started with 75R. Proved to be way too hot, so added a second 25W resistor in series for 120R total. Silly waste of space. Maybe I'll split the cathodes later.
Raoul Duke
Post by Raoul Duke »
Really innovative layout - but still looks TW at heart. Very impressive!
Marc
I installed a crossline MV (Type 3), and am enjoying the result. However, I accidentally connected the MV pot to the plates of the PI, instead of the power tube grids. What do you think the result was? Noise? Badly scratchy pot? Weird tone? None of the above! I moved the wires to the proper place, and the MV sounded exactly the same as when wired wrong.
maxkracht
Post by maxkracht »
xtian wrote: Wed May 14, 2025 3:53 am I accidentally connected the MV pot to the plates of the PI, instead of the power tube grids.
Makes sense, though a nasty trick on the next guy to work on it if you didn't correct the error.
Built a cherry hardwood cabinet with walnut valence, gloss polyurethane, and got the faceplate installed. Glamor puss shots.
Raoul Duke
Nice looking all the way around! Bet it rips.
Marc
Jered
Post by Jered »
Beautiful work
