Have a scratch build brown Vibroverb 6G16 I am having an issue with. Well, two issues.
Firstly, schem/layout here.
The first order problem is that I can't seem to get the 6L6GCs to bias up to anything over 7w dissipation.
I have a 10k bias resistor in there now. Plate voltages around 394-395V, plate current at 16-17mA. Pin 5 voltages are -45V.
When I had a 10k pot with a 15k resistor in there originally, I had plate voltages of 406-407V, plate current at 11-12mA.
Of course the amp has an ugly type of distortion when I hit a chord moderately hard. Kinda like a splat... I guess this is some kind of crossover distortion, possibly due to too cold of a bias?
I've never seen a Fender with a bias resistor lower than 10k... but do I just keep lowering the bias resistor to get it to bias warmer (he asked, rhetorically)? That doesn't feel right...
The other problem is that the amp "chirps" with the pulse/speed of the trem when I turn up the intensity. I'm thinking this could be related to the above as the trem works off the bias? And/or it could be a lead dress issue...?
Any leads (pun intended?
TIA,
Chris
