No Sound or anything in Soldano.
Oddvar R
Post by Oddvar R »
Hi. Just put up my Soldano Slo Clone from C3amps and had som minor crackling in it. Thought maybe a tube problem, so I started changing tubes. Unfortunatley I accidently put in a 5881 tube where the steering pin was faulty, so I had it in the wrong way, resultang in a smoke situasion in the 470r resistor. Result: The amp turns on, voltages seem to be ok, but no sound and no anything in the speakers. I suspect issues with the OT, but I can't measure any problems so far. Any idea of what to look for?
R.G.
Re: No Sound or anything in Soldano.
Post by R.G. »
Measure the no-signal voltage on the power supplies and all tube pins.
"For every complex problem there is an answer that is clear, simple, and wrong"
H. L. Mencken
Stevem
Post by Stevem »
Try pumping the audio from the effects send jack into another amp.
Stevem
Post by Stevem »
Truthfully I can't see how the short you created from putting that tube in wrong which burned up that one screen resistor would have harmed the OT.
If you posted a schematic of the amps power supply then we could see if the amp has a HT fuse which I suspect is now blown.
jabguit
Post by jabguit »
Stevem wrote: ↑Mon Jun 16, 2025 8:58 am
F2?
Jack Briggs
Briggs Guitars
R.G.
Post by R.G. »
Stevem wrote: ↑Mon Jun 16, 2025 8:58 am Truthfully I can't see how the short you created from putting that tube in wrong which burned up that one screen resistor would have harmed the OT.
Dead on target. Could be the B+ fuse, could be a rectifier, but highly, highly likely a power supply issue.
Extremely unlikely to be the OT.
H. L. Mencken
syscokid
Post by syscokid »
jabguit wrote: ↑Mon Jun 16, 2025 10:46 am
F2?
Yes
And the Welwyn W20 Series 470 ohm 3 watt screen resistor.
Greg
