The 1ohm Resistor Method for Biasing
desertmouth90
Does anyone have any diagrams for adding 1 ohm resistors for 4x6L6GCs on an Overdrive Special or something similar?
Also do I have to remove the original grounds pin 8 too?
thanks
thanks
Re: The 1ohm Resistor Method for Biasing
You place 1R resistors between the power tube socket's pin 8 and ground. So yes, if pin 8 is currently connected to ground, you have to break this connection, and solder in the resistor instead.
desertmouth90
If you want to measure your tubes in pairs, you can keep the link and use one resistor to ground per pair of tubes. If you want to measure individual tubes, which I would recommend, you need to one resistor per tube and no connections between them on pin 8.
desertmouth90
I used this, now it’s drawing too much current! And the bias isn’t normal on the output of the pot! Really weird
Adding the resistors will not change the existing bias. Post photos of your work.
What's drawing too much current? Adding 1Ω resistors as shown will not affect tube current.
What does this mean? Numbers please. The 1Ω resistors have nothing to do with the bias voltage.And the bias isn’t normal on the output of the pot! Really weird
...Steve
desertmouth90
I think I wired up the bias pot wrong
Before and after attached.
desertmouth90
Probes on the Ground and across the 1ohm resistors aren’t showing anything…
It looks like you're using Pin 1 as a mounting point to hold the grid stopper resistors running to Pin 5.
Your diagram here shows the grid stopper resistors going straight to Pin 5, with no connection to Pin 1. You must do it that way, or you ground your Bias Voltage, put 0vdc on the control grids, and send the output tubes into meltdown.
desertmouth90
I thought on a 6L6 pin 1 doesn’t do anything?
Since I reversed the 27k resister and -ve bias voltage lugs there is no buzz.
sluckey
It's OK to use pin 1 as a tie point for the 1.5K grid resistor. Thousands of Fender amps can attest to that. BUT!!! Pin 1 cannot also be connected to pin 8! Remove any jumper between pin 1 and pin 8. And connect the 1Ω resistor directly to pin 8.
Looks like you forgot to solder the grid resistor to pin 5. And every solder joint in the pic looks terrible. Not gonna be reliable if all your solder connections look like this.
...Steve
sluckey
It doesn't. but your little layout shows pin 1 jumpered to pin 8! YOU CANNOT CONNECT PIN 1 TO PIN 8 AND ALSO USE PIN 1 TO MOUNT THAT 1.5k GRID RESISTOR!
Depending on how long your amp was turned on you may have destroyed the output tubes and output transformer. 10 seconds may be a killer.
...Steve
desertmouth90
I didn’t do that jumper… I kept them separate.sluckey wrote: ↑Mon Jun 23, 2025 10:46 pmIt doesn't. but your little layout shows pin 1 jumpered to pin 8! YOU CANNOT CONNECT PIN 1 TO PIN 8 AND ALSO USE PIN 1 TO MOUNT THAT 1.5k GRID RESISTOR!
desertmouth90
It’s a fair point, I used awful solder on this project. But however I will be rebuilding it at some stage. The idea is to get it working firstsluckey wrote: ↑Mon Jun 23, 2025 10:41 pm It's OK to use pin 1 as a tie point for the 1.5K grid resistor. Thousands of Fender amps can attest to that. BUT!!! Pin 1 cannot also be connected to pin 8! Remove any jumper between pin 1 and pin 8. And connect the 1Ω resistor directly to pin 8.
