Sunn 1200S Schematic
JCM89
Post by JCM89 »
Hello Tube Amp community,
I am working on a Sunn 1200S from 1969 and I am looking for the the proper schematic. I found a schematic off of EL34 world for a later 1200S but it shows a Diode rectifier, the amp I am working has a tube rectifier.
The issue here is that the amp is motorboating. There was some work done to the amp recently, a new three prong power cord and new filter capacitors from the looks of it. The power cord was installed incorrectly causing the fuse to blow which I was able to fix. I would like to know the the correct value of the filter capacitors to see if the correct ones were installed. That's really what I am looking for off of the schematic.
Any help would be greatly appreciated.
Dan
Stevem
Re: Sunn 1200S Schematic
Post by Stevem »
This is a 2000S which is likely what your power supply is .
sluckey
Post by sluckey »
...Steve
Stevem
Post by Stevem »
That’s a 1971. He’s got a 69.
With todays average wall voltage the first two filter nodes really need to be made up of stacked 300 volt filters with balance resistors.
Roe
Post by Roe »
frag jan zuerst sells 550v caps that are speced for 600v surges
LOUDthud
Post by LOUDthud »
Does the 1200S have the Tremolo and Reverb board ? The earliest amps did not have this PCB and only had four knobs. Later amps added a small circuit board with solid state circuitry for Reverb recovery and an optical Tremolo oscillator. The Reverb drive was a tube with a matching transformer. These amps had seven knobs.
Kagliostro
Post by Kagliostro »
I suppose that as the Solid State Rectifier version also your 1969 amp has 4 Power Tubes
You don't specific which is the Tube Rectifier on your amp and say
.... the amp I am working has a tube rectifier ....
has a tube rectifier (no more I suppose)
Assuming it is a GZ34 like in the Sunn Sceptre of 1969 (but will it be able to feed enough current for 4 Power Tubes ?)
you can see that the first cap is a 30uF rated 525V
on datasheet the GZ34 first e-cap max value is stated at 60uF
so 30uF to 60uF is the range in wich you can put the first e-cap value
Is the Tube Rectifier really one and is it a GZ34 ?
Franco
JCM89
Post by JCM89 »
Thank you all for the replies.
The tube rectifier is two GZ34 tubes. There are two 3-10C chokes, the first two installed Caps measure at 100uF.
LOUDthud wrote: ↑Wed Oct 29, 2025 8:57 am Does the 1200S have the Tremolo and Reverb board ? The earliest amps did not have this PCB and only had four knobs. Later amps added a small circuit board with solid state circuitry for Reverb recovery and an optical Tremolo oscillator. The Reverb drive was a tube with a matching transformer. These amps had seven knobs.
This Amp has 7 knobs and a PCB. Knobs are labeled Reverb, Depth, Rate, Contour, Bass, Tremolo, Volume, and a Midboost Switch. It has a 12Au7 tube and a small transformer. The only reason I said it was a 69 is because there is a date marked on the inside of the chassis coupled with the fact that it is a tube rectifier, I could be mistaken on this model year though.
So far it looks like the schematic of the 2000s posted by SteveM is the closest.
JCM89
Post by JCM89 »
Correction, the Chokes are not labeled 3-10C. The number on the two chokes is 27-3100 -- 606927
JCM89 wrote: ↑Wed Oct 29, 2025 3:33 pm The number on the two chokes is 27-3100 -- 606927
606927 is Schumacher, 27th week of 69.
