SE OT with screen tap
lonote
Post by lonote »
I played a date a couple weeks back with a fill-in guitar player that played a Tele through a modified SE record player amp (He thought a Cailifone, internet is saying a Newcomb). It sounded great & it was amazingly loud, even in a band setting.
I gave it a quick look as we were packing up & was able to get a bad phone pic of the schematic which was pasted into chassis. The only mods he said he had made were a couple input resistors & I have not gotten a chance to follow up with him for more information after getting to check out the schematic.
Looking it over, one of the things I am not at all familiar with is the separate OT screen tap (& intentionally higher voltage than the plate).
I am assuming he modded the phono channel as he DID use the tone controls.
Any insights from those more knowledgeable?
Apologies for the photo quality or lack thereof.
EDIT: Guessing this is UL..Did not realize Ultra Linear could implemented on an an SE output. Had it firmly in mind that it was a P-P thing only.
flemingmras
Re: SE OT with screen tap
Post by flemingmras »
That is a 40% "Ultra Linear" tap. It combines characteristics of triode and pentode operation, giving the high power output of pentode mode with the linearity of triode mode. The closer the tap is to the plate, the more "triode-like" it performs. The closer to the B+ tap, the more "pentode-like" it performs.
Never seen it done on a Class A Single Ended amplifier.
Stevem
Post by Stevem »
Single ended UL 75 watt 28 lb output.
The darn thing tips the scales like does many combo amps with a 10” speaker !
So one EL 84 was loud enough in a band setting with a Drumer?
How many speakers was the guy playing through?
lonote
Post by lonote »
Stevem wrote: ↑Fri Jul 31, 2026 9:31 pm Single ended UL 75 watt 28 lb output.
That is a crazy OT, I would not want to haul around an amp with that in it.
But yeah, a 4-piece with a drummer. He was using 1-12" guitar speaker, no idea what it was.
A kind of small room, but moderate volumes (old-school electric blues) & you could hear the thing pretty well.
He has an EE background/repair experience & he said it wasn't even recapped.
