Gibson 355 Waffle back tuners
angelodp
Post by angelodp »
Hi, have a nice 355 here with waffle back tuners. They have the requisite patina and some grunge. They turn well but a tad loose. I can clean these up with naphtha and I am wondering about repacking. If you have experience with this sort of thing. Is it fine to bathe them in mineral spirits to clean, then repack through the tuner stem space with lithium grease? Or, clean with Naphtha and simply add grease? Any preferred lube I should know about?
Reeltarded
Re: Gibson 355 Waffle back tuners
Post by Reeltarded »
White grease. Have you seen one disassembled?
Reeltarded
Check this thread. Down the page you start seeing guys talking about drilling out the brass rivets. Don't have to use a drill, just the bit or even a push drill is better.
What you described could be the string shaft gear is loose and overriding the driving gear,
1) I drilled out the 2 eyelets that are holding the tuner together using a 1/8" drill bit. They are Brass and it is soft metal so it drills out easily.
2) Fixed the issues I was having (it was bent). By taking it apart I was able to put it in a vice and bend it back into shape.
3) Purchased some new eyelets (brass, 1/8" by 1/4") Thanks to RickRandoms advice
angelodp
Post by angelodp »
Thanks, what thread please? After working them for a while they seem to be behaving. Guitar was not used for a long while.
didit
Post by didit »
Reeltarded
Sorry about that, I decided to copy the info then got distracted before pasting the link!
Ohh! 65? I have a "61 mono with the most vain serial number of any guitar I have ever seen.
1961 heh
didit
Post by didit »
Cherry !!
tylerdavis87
Post by tylerdavis87 »
Sounds like a nice 355. Are the tuners original Klusons or repros? That can change how you clean them up. I’ve heard mixed things about soaking them fully in mineral spirits, since some people say it can loosen the plating, so I’d test one first before doing the whole set.
I’ve had similar situations when cleaning old parts in my car garage, and trying one piece first always saved me from messing up the rest.
Reeltarded
angelodp wrote: ↑Sun Jul 06, 2025 3:17 pm Thanks, what thread please? After working them for a while they seem to be behaving. Guitar was not used for a long while.
WD bought Kluson and jacked the prices. Chicago Music Exchange has a few sets of perloid and metal button versions left that are perfect fit for $105 instead of $190!
Insane.
