If you were to build a tremolux......
- dragonbat13
I have wanted to build a deluxe for years. Now I think I want to build a "Deluxe with Vibrato" aka: TREMOLUX!!!
But it doesn't have to be authentic to any particular fender amp. I want a 2x6v6 tweed amp with a tube rectifier, the best non harmonic type vibrato circuit, with whatever speaker compliment (4x10,3x10,1x12,1x15,ect.) narrow panel tweed covered combo.
Dont care how loud it gets, want a good blues amp out of it. Raw blues, ZZtop blues. Not SRV punchy clean blues. I got enough amps for that. Looking for something a bit louder than my 54 princeton in a narrow panel cabinet (for the different looks).
Any recommendations? I would think a 15 inch speaker would not work out well, but really like the 3x10 idea. Although the Deluxe tone really has the 1x12 requirement I suppose?
Have I confused my question enough?
What would you build?
Re: If you were to build a tremolux......
I happened across this series of vids a few years and it stuck in my mind that I really need to build myself one of these one day
As it’s a ‘55, it’s probably the cathode biased 5E9/A, rather than the fixed bias 5G9.
So bias modulation applied to the (paraphase) phase splitter’s shared cathode, hence it should get largely cancelled out due to being common mode.
- dragonbat13
Awesome video. The 5e9a was the circuit I was leaning towards the most.
Hello -
About a dozen years ago I put together a Mission 5E3 kit. Came to the conclusion tweed deluxe was not my thing, and after some research and careful listening arrived at 5E9-a. The modifications needed were easily retrofit. Missing the socket for tremolo obviously. However at it's core there is that touch-sensitivity and warm tone. Recommended.
Best .. Ian
Best .. Ian
I wonder what seems to make that much of a difference between the 5E3 and the 5E9A, beyond the tremolo. Is it all in the phase inverter?
All I can see different is the phase splitter and the output valve operating point.
As the screen grid HT dropper is half the 5E3’s value, the screen grid voltage will be a bit higher, so the valves will idle a bit hotter.
Thanks. Looks like I was too curious about the phase splitter to notice the resistors.
My buddy Billy Yates!pdf64 wrote: ↑Tue Apr 13, 2021 2:26 pm I happened across this series of vids a few years and it stuck in my mind that I really need to build myself one of these one day
I have his personal Red Jones TW style amp. It's a beast!
cheers,
Jack Briggs
Briggs Guitars
Briggs Guitars
Sum of several differences. Paraphase inverter is central. Lower B+ dropping resistance. Key coupling cap is 0.02uF roughly replacing one that was 0.1uF. All together now, nice warm gradual transition furry-ness versus ratty cathodyne goop.
Sorting my workshop recently and happened to happen on notes from the surgery. See below, and apologies for the scribbles as these were captured just to guide me not provide advice for others.
Best .. Ian
Pdf64, I seem to recall you mentioning noise effects from adjacent common-cathode preamp stages? This 5E9A has that, as well as no NFB off the OT as in the 5E3. Relevant? [Edit: Never mind, that second one is the PI.]
Just plug it in, man.
May be thinking of V4 common cathode in Fender twin channel reverb amps?
This is similar but different, due to the significant attenuation between the stages.
I always wanted a 5G9. In the videos I've seen of the 5E9As they always sounded good to me. Here's something I mashed up in a schematic but never built. It's a 5E3 with the Vibrochamp trem. I used to have a silver face Vibrochamp and the trem really was very nice:
Hmmm... The more I think about this, I would go with a 5E9A with the 5D3 phase inverter.
That would lose the benefit of the modulation signal being (largely) cancelled out, due to it being common mode in a circuit carrying balanced signals.
