daxliniere wrote: ↑Wed Jan 22, 2025 12:58 pmThe tank originally lived in the bottom of the combo, but now that I've 'beheaded' it, the tank needs to be closer to the rest of the amp.
Somehow I missed that you have it in a head cab. In that case, I think you are doing really well with noise!
It IS pretty crazy how the tank orientation/proximity is so variable with generating noise & seems somewhat random to the specific tank & amp.
I built a Champ circuit with 2-tube reverb & tried to install it in a head cab. Tank on the bench it was fine, but anywhere near the amp it was an unacceptable level of noisy.
I tried all kinds of shielding, then isolating the reverb internals & shielding the shell, etc. but finally gave up as it was a lost cause & it became a combo.
Roe wrote: ↑Wed Jan 22, 2025 7:14 pmtry and see if it helps. use 22k or higher values on each grid
I'm a bit confused. There isn't current a series resistor feeding the parallel grids. The pairs of 470K resistors seem to just be isolating each channel output from the other's output. (But this is just a guess.)
If you're suggesting they're a new thing that needs to be added, that's fine; very easily done in-line with the wires going to pins 2 and 7. (with appropriate heashrink insulation, of course).
each grid needs a dedicated grid resistor placed as close to the pins as possible
So this would be an addition to the original design, yeah?
What value would you suggest?
Also, I just discovered that if I have the reverb turned to maximum, the HF of the amp is rolled off. It sounds like it's creating a highly resonant low-pass filter. The difference is massive. Any ideas?
Edit: fixed typos
daxliniere wrote: ↑Thu Jan 23, 2025 10:46 am
Also, I just discovered that if I have the reverb returned at maximum the HF of the amp is rolled off. It sounds like it's creating a highly resonant low-pass filter. The difference is massive. Any ideas?
perhaps try to rewire the reverb pot in the SSS manner: swap hot and wiper (not ground). This may help perhaps unless you t turn the reverb to 10
Cool, thanks Roe.
So my to-do list is:
1) Replace 470R 1W carbon resistors on output tubes with ultra low noise Vishay metal films. (waiting on stock)
2) Swap reverb pot in and out wires
3) Add 10-22k resistors in series with reverb drive grids
For the 'Miller Effect' caps (Cgk) I added to the first stage triodes for both channels, I used 100V caps because that's all I had to hand at 100pF. Are these fine or do they need to be changed for a higher voltage rating?
daxliniere wrote: ↑Thu Jan 23, 2025 1:42 pm
Cool, thanks Roe.
100v is ok between grid and ground or cathode but not if you connect it to the anode/plate.
1) won't matter much but keep the 1w rating since these work as fuses if tubes short
On the reverb noise, I have two of these amps that are in head cabinets. I replaced the discrete wires leading up to the reverb knob with a shielded cable connected directly to reverb pot. I cut the now unused copper patterns on the board right at the pot so they would not act as antennas. Helped quite a bit reducing feed back and noise.
