6G6B & phat closed back cabinet
Fender Amp Discussion
ToneMerc
Post by ToneMerc »
Finally got my 6G6B rig finished tonight. Here's my personal 6G6B head that I finished up 2 months ago and the cab that Taylor covered for me recently. It's a deep closed back cabinet with a Weber ceramic Michigan paper dome 12" speaker.
http://ampgarage.com/forum/download/file.php?id=25202
TM
dcribbs1412
Re: 6G6B & phat closed back cabinet
Post by dcribbs1412 »
Thats a real beauty TM
any thoughts on the blue Sozo's?
Congrats
Darin
ToneMerc
Post by ToneMerc »
dcribbs1412 wrote:Thats a real beauty TM
Congrats
Darin
The one I built for my customer I used the yellow Sozos and a MCI tweed Bassman OT. I slightly prefer that one with a hot humbucker and the modified bass channel. This one has the Speer KOA CF resistors, Mercury Magnetics tone clone OT and hands down the normal channel of this one is preferred. My customers amp does have a GZ34 rectifier as he was adament about it. Nevertheless, both have the correct schematic voltages using the modern higher AC line voltages.
Honestly, I don't have enough tangible evidence info to say the blue is better than the yellow in this circuit. I will say that both sound decent and I would not hesitate to use the yellow again, especially with the modified crunchy bass channel.
Mike
Great looking amp and speaker cab.
CHIP
Post by CHIP »
Very nice, TM. I'm in the process of building one right now. I followed your lead with the Speer KOA CF's and Blue Zoso on the normal channel. Looking forward to hearing how it turns out. Thanks for your posts.
mr_hankey
Post by mr_hankey »
I'm running my '64 6G6B into a cabinet built to original dimensions, but with two (15") Eminence Legend 151's shoehorned in. As you can imagine, it has bass for days.
The cab was still missing its grillecoth when I took this picture.
It still had the original caps when I bought it in 2007. (I've replaced them, obviously.)
Toppscore
Post by Toppscore »
mr_hankey wrote:I'm running my '64 6G6B into a cabinet built to original dimensions, but with two (15") Eminence Legend 151's shoehorned in. As you can imagine, it has bass for days.
Are you playing guitar or bass or what through those two 15" speakers?
I've been seeking a solution for 15" speaker output.
Do you like the 2x15s in gutiar blues mode?
Fender originally had the 5B6 1x15 and I've been thinking
about a cabinet for my amp heads. 2x15 has me thinking.
How much does the speaker cabinet weigh?
What ohm values are the speakers for the Bassman
16-ohm speakers or 8-ohm speakers?
How is the "high-end" and distortion tones
if this Bassman is used for guitar?
Thanks for the info. Toppscore :)
Fan of Fender Trainwreck Dumble
mr_hankey
Post by mr_hankey »
I've only used it for guitar, but I imagine it would sound pretty good for bass as well. They're two 8 ohm speakers, so I put I two jacks on the back for 4 and 16 ohms.
The sound is loud, clean and BIG. The high end response is as good as a smaller speaker. I wouldn't call it better or worse than a 2x12 cab, just different.
I originally wanted to put just one 15" in there (Vibroverb style), but ended up buying two because I couldn't find any 4 ohm speakers that weren't more expensive than both of those Eminences put together. I would have had to import a 4 ohm speaker from the US, with shipping and tax and what not.
I'm not sure on the weight, but it's probably 4-5kg heavier than with 12's.
Toppscore
Post by Toppscore »
Cool. Helpful.
I will be designing or making a 15" speaker
or combination cabinet that includes a 15" speaker.
Personally, I do enjoy the guitar bass tones more
than guitar higher-end treble tones. Even the high
guitar notes with a clean tone on a 15" speaker
is appealing. Toppscore :)
