Fender Bandmaster reverb: Curing a Ticking tremolo
Folks
I am sure this has been discussed here before
Is there a quick fix for a ticking tremolo? (I know it occurs fairly often in these amps)
I believe its due to coupling issues or layout from what I recall
Any insight please
Markus
Any insight please
Markus
.........Now where did I put it?
- FUCHSAUDIO
Re: Fender Bandmaster reverb: Curing a Ticking tremolo
.01 cap on the 10-meg (?) resistor and relocate the capacitor from the tag board to the trem jack, onto the main board. Do a google search, it's pretty well covered. Also, the footswitch cable can sometimes cross couple the tremolo noise into the reverb return if the cable is not well shielded. You can get it nearly (if not completely) silent with a little minor work.
This looks right to me. Here is the "official" version.FUCHSAUDIO wrote:.01 cap on the 10-meg (?) resistor and relocate the capacitor from the tag board to the trem jack, onto the main board. Do a google search, it's pretty well covered. Also, the footswitch cable can sometimes cross couple the tremolo noise into the reverb return if the cable is not well shielded. You can get it nearly (if not completely) silent with a little minor work.
Thank you folks!
Much appreciated!
M
Much appreciated!
M
Hello Mods: I got the Firefox warning not to e access the PDF. Sorry...I know this has been a continuing problem. I thought I'd mention it. Whoever, it is possible to get unblacklisted. I think you have to keep trying. Meanwhile, at my own peril, I ignored the warning.ATL Strat wrote:This looks right to me. Here is the "official" version.
To the topic of ticking, sometimes the board can become conductive. The fix might be to simply lift the connection into the air rather than using the eyelet. Pictures here: http://timeelect.com/jbl-twin.htm
Thanks Phil
This amp is pristine and the board looks very good to me
(though it doesn't mean it's not conductive)
I will try the suggested steps first
Markus
Markus
Timely post! I too have a Bandmaster Reverb with a ticking tremolo. I'll put this info to work as soon as I get my 5b6 sorted out.
I will give feedback soon
Just finished the wire re- routing and the cap
BTW Why MYLAR only?
M
BTW Why MYLAR only?
M
7ender spec? Shouldn't make a bit of difference though.Markusv wrote:BTW Why MYLAR only?
M
U-huh
I get it
I have orange drops (generic) kicking around
I get it
I did the mods
Bunched the wires at the tube
Moved control wires away from the tone stack wires
Installed the capQuiet as a mouse!
Thanks all!
Markus
Thanks all!
Markus
Cool!
You can't get much better than that with a fix.
(saved to my archive)
