nfb resistor question
Marshall Amp Discussion
harris51
Post by harris51 »
I have a jtm45 with radio spares ot running a 8 ohm load I have a 27 k resistor in there now would a 47 k make the amp a little more gainy?
Colossal
Re: nfb resistor question
Post by Colossal »
Yes. For more fun and gain, leave the 27k fixed and insert a 100-250kB pot in series. Adjust to taste.
Just note that you will be driving the output tubes harder so they will clip sooner, as such you may also want to bias them a tad cooler depending on what your ears tell ya!
roberto
Post by roberto »
As for the pot in series on the NFB, I prefer 100k lin or 250k log.
This way you have more control on the whole range.
LPC78wino
Post by LPC78wino »
Stevem wrote:Just note that you will be driving the output tubes harder so they will clip sooner, as such you may also want to bias them a tad cooler depending on what your ears tell ya!
So when a higher value NFB resistor is replaced making the amp a little more gainy, resulting in clipping sooner; will drive the output tubes harder ?
I also see, if one had a high plate voltage, that biasing a little cooler will prolong tube life, but more importantly dial in a tone that one is satisfied with.
If one has a 47k upped to a 100k, then I would be conscious of biasing a tad under (to taste of course) and have the option of the 3 taps. (something like that ?)
"What does that do ?"
gui_tarzan
Post by gui_tarzan »
Do you have pics of the outside and inside? I just finished updating a '64 JTM45 and you're right, it does need a little more gain than stock but boy are they sweet.
--Jim
Reeltarded
Post by Reeltarded »
First thing I do on a 45 is swap a 470k divider pair in place of the 270ks before V2. Mostly about bringing the 'chest' out a little.
TimmyP1955
Post by TimmyP1955 »
Reeltarded wrote:First thing I do on a 45 is swap a 470k divider pair in place of the 270ks before V2. Mostly about bringing the 'chest' out a little.
Doesn't that make the bright input even brighter?
Roe
Post by Roe »
Colossal wrote:Yes. For more fun and gain, leave the 27k fixed and insert a 100-250kB pot in series. Adjust to taste.
yes, 22k + 250k pot into 16ohms secondary
rp
Post by rp »
This is a real 45, not a reissue or clone? +1 Please post good picts.
