This is part of the 180w mod on a 1959 model to partial Major mod 1967.
Jimmy Page's sound is much like a JTM-afied Major at about 4-5 on the volume. That completely makes sense.
I know nothing about this mod, do you mind sharing this information?Reeltarded wrote: ↑Sun Feb 23, 2025 11:24 pmThis is part of the 180w mod on a 1959 model to partial Major mod 1967.
Mark wrote: ↑Mon Feb 24, 2025 1:13 amI know nothing about this mod, do you mind sharing this information?Reeltarded wrote: ↑Sun Feb 23, 2025 11:24 pmThis is part of the 180w mod on a 1959 model to partial Major mod 1967.
Thanks for your help.
agreed. with a 5nf bright cap and the volume below 6 you get close with a very powerful 100w amp. Also, you really need those thin bass strings, like 22-30-38Reeltarded wrote: ↑Mon Feb 24, 2025 3:41 pmMark wrote: ↑Mon Feb 24, 2025 1:13 amI know nothing about this mod, do you mind sharing this information?Reeltarded wrote: ↑Sun Feb 23, 2025 11:24 pm
His heyday sound with the first version of the 100s turned into 180s sound like a generally mild JTM shared cathode with a giant bypass on the volume control, warmer and wider than a Major but similar hammer strike. heh
There are serious if curious elements within TAG flaunting pictured forks who’ve rejected existence of any “blonde” Fenders.Reeltarded wrote: ↑Mon Feb 24, 2025 10:59 pm There is a little bit of a blonde Fender in there, at least you can get a similar feel from a somewhat underdriven blondey at a volume that doesn't bruise the 5th row.![]()
I wonder if it’s possible to build a low wattage version and still have the sound?Reeltarded wrote: ↑Mon Feb 24, 2025 10:59 pm Super tight. Like a gnarly Twin Reverb, sometimes even a UL model. It just goes over every top without being especially grinding.
It accounts for some of the slop, because it takes balls and a lot of attitude to stick yourself out there with a 2 ton direct box.
I have always thought people who wanted to sound like an average of Jimmy Page don't really want an average Marshall but instead some Fender amp.
Not really in my experience. but attenuators do work. and the page sound does not require much distortion. and its is 6550As hereMark wrote: ↑Wed Feb 26, 2025 7:51 amI wonder if it’s possible to build a low wattage version and still have the sound?
The amp would weigh a ton and be deafening loud. I’m not a fan of putting KT-88’s in a Marshall using the stock transformer set as they have to be biased very cold and they really don’t sound better than EL-34’s in my opinion.
