JTM45 RI conversion
Marshall Amp Discussion
PaisleyTube
Re: JTM45 RI conversion
Post by PaisleyTube »
jelle wrote:
PaisleyTube wrote:What's the B+?
Most reïssues I've seen were way below 400 Volts while a couple of real/old JTM45s were around 450 Volts....
Hi Chris! How are you?!
See my first post. :D
Pretty good.
Voltage: Kinda low ( but correct for a reïssue), the amp becomes much "larger" imo with a higher/"correct" B+
Chris
Love, peace & loudness!
Roe
Post by Roe »
yes, original voltage charts show 440 and 450v. I looked at one original recently that had ca 450v, depending on bias. most originals used the 1k flying resistor, but the RI omitted it, leading to screen voltage exceeding plate voltage
+1
+ different filtering
Is the choke right after the ot-centre-tap or in front? did forget to check that and/but the old schematics are pretty unclear to me regarding that.....
tia!
one schem shows CLC filter (before OT), but all known jtm45s seem to have the choke between OT and screens. only the latter has the right sound
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
PaisleyTube
Thanks!
It was a '65 or '66 I did measure, all voltages did match the schematic but I didn't look at the choke-position at that time....
Again: thanks!
Chris
BIG Dave
Post by BIG Dave »
I have a JTM45 RI that I changed the filter caps to 16x16 and 32x32, then put in all NOS glass consisting of Mullard pre's and GZ34, and GEC KT66. Matched it up with a JCM800 2x12 (model 1936) loaded with Celestion Blues. Sounds pretty darn good so I'm done (for now).
BIG Dave: '63 Princeton, '67 SFDR, '68 Marshall 4x12, '71 Marshall JMP50, etc...
