JCM800 2204 combo build
Marshall Amp Discussion
rogb
Post by rogb »
WARNING: not very neat and tidy 8)
Just thought I would post a few pics of my JCM800 build and talk you through a little of what went on.
I had a Marshall build in mind back in 2012 when I saw Mark Fowler's Stage 50 based on the 2204.
It seemed a great addition to my #102 and AB763, especially as I wanted to run the Dumble and Marshall as a dual amp rig.
Martin Manning then suggested the Classictone 40-18095 PT modelled on a Drake I believe which was being developed at that stage and features 3 secondary taps of 560v, 625v and 690v as well as a 5v rectifier tap.
Well I was pretty busy on my 102 build leading up to Christmas but I built the 2204 combo cab over the holidays from a good dry 21mm pine floorboard and made the baffle from 18mm MDF. Covered it in British Racing Green tolex and Marshall salt n' pepper grille cloth. A new G12-65 Heritage was installed, coutesy of the same lovely ladies in Suffolk who made my original one back in the 80s!
The chassis 18.5 x 6.5 x2.5 came from Modulus Amps in Scotland as did the block logo nameplate.
I finished the 102 in January and got straight on with the 2204. I ordered the PT from Triode as soon as it was available. Very good comms also from MC, by the way. OT used was an MC 18025 and the 5H 120mA choke. The set arrived from Triode exceptionally well packed!
I got on and started planning the layout and drilled board which I got from Modulus as I am lazy....! I used a combination of Metro and Ceriatone layouts with the JCM800 schematic.
A PPIMV is a must for me so that was fitted too.
I had a few NOS resistors left from my 102 order so these went into the mix.
Filtering was via F&T, 2 x 50+50uF cans and one 32+32uf dual on the board.
I added an octal socket for a GZ34 tube rectifier and wired up the 5v but have left it for now as it sounds fine as it is. I don't think there is much to be gained from running a tube as the capacitance needs to be reduced to 50 from 100uF when the tube is being used.
I tried all 3 HV taps but the 625v gave the best balance of headroom and driveability as you might expect....
Plates are 435vDC biased at 35mA.
Grounding is a star ground near the PT, I put in the solder tags for a Larry scheme if it was noisy -it isn't.-
Mods to the circuit are:
PPIMV in place of the 220K bias resistors.
It works very well and is essential IMO.
.047 bass cap in place of the .022.
Mid pot 50k instead of 25k.
Single input so no treble peaking circuit.
Bias test points.
Yesterday I got crazy with the board mounted bias trimmer and dropped in a pot at the back in the tube/diode switch hole. Much better!
Re: JCM800 2204 combo build
rogb wrote:WARNING: not very neat and tidy
Disagree. Looks great!
rogb
Post by rogb »
Thank you :)
Bob S
Post by Bob S »
Looks great - the cab is nice too !
Looks neat & tidy compared to some of my efforts...
The Brit Racing Green is icing on the cake.
Especially for Brits.
Well executed - bet it's fun to play.
Plus combos are easier to lug around.
Nice One !
Why Aye Man
Reeltarded
Post by Reeltarded »
Oh god look at the time you wasted! I could have built four while you were twisting wires and measuring wires with a mic gauge!
Beautiful!
rogb
Post by rogb »
Thanks Miles and Bob, don't think I measured too many wires lol.
I does need some more tidying but it sounds good and is quiet. When you turn it upside down and shake it nothing falls off -job done!
Miles, I tried the 500pf but didn't like it, it seems bright enough through the G12-65.
I now have a Little 59 in the bridge of my Strat but don't tell Dave Allen, shhhhh :oops:
Now that kicks some butt!
Hey there are 3 threads on this great amp :lol:
rogb
Post by rogb »
M Fowler wrote:Hey there are 3 threads on this great amp :lol:
I think I am trying to make a point without subtlety about an amp BUILDING ( and ABY modding :D ) forum....
Reeltarded
hah
I just noticed your using a Dumble style cab that's a No-No in my book WTF :lol: This is a Marshall, well better then a Marshall in my opinion. :)
rogb
Post by rogb »
M Fowler wrote:I just noticed your using a Dumble style cab that's a No-No in my book WTF :lol: This is a Marshall, well better then a Marshall in my opinion. :)
:?: It's a cab styled after the Mojo cab used on your Stage 50. I sized it to (a) match my small box chassis and (b) to match the 102 cab for stacking :D
I like my mojo cab, works well for many different amps with chassis size of the Marshall JTM.
I should just put Mikey to work making me a bunch. :)
lumox0013
super work
Post by lumox0013 »
cudos very sharp board work, are you running the standard 800 feedback values and to what tap?
Live , Love , Learn
rogb
Re: super work
Post by rogb »
lumox0013 wrote:cudos very sharp board work, are you running the standard 800 feedback values and to what tap?
Thank you - standard 2204 AFAIR - 100K into the 4ohm.
I recently wired up the LOW input as I figured it's a Marshall who needs low
:D but it is really useful to play without gain sometimes (I think...) so I use the 2204 on low with my 102 50w to add a warmer dryer and different dimension to the Dumble effected clean. It's just an excuse to get 100w going, that's all 8)
