74 Super Lead radio interference
Marshall Amp Discussion
chadb
Post by chadb »
Hey Guys,
I recently scored a 74 super lead on the cheap and have done my best to convert the circuit back to its original specs. Someone had hacked a bunch of holes in the chassis and added a relay switching system and a bunch of other crap...
Anyway, other than adding a PPIMV and a half power switch, the circuit is now stock. The amplifier works, biases up just fine, and sounds pretty good, but I'm getting some terrible radio interference, and a little more hum than I would like. I assume I'm getting some AC in there where it shouldn't be (yes I completely re-capped the power supply and all other electrolytics).
If anyone has any suggestions, It would be greatly appreciated.
Re: 74 Super Lead radio interference
AC hum would be power supply or bias cap.
Blackburn
Post by Blackburn »
chadb wrote:Hey Guys,
That's known as the Spinal Tap mod. :lol:
chadb
Post by chadb »
That's what I would assume as well, but as I've replaced all 6 power supply caps and both bias supply caps with brand new ones, I wouldn't think that would be the issue.
JazzGuitarGimp
Post by JazzGuitarGimp »
Not sure how large a hole in the chassis has to be to allow radio waves in, but if any of the holes you've described as 'hacked a bunch of holes in the chassis' are larger than, perhaps 1/4", you might consider covering them up with metal plates that are well-grounded to the chassis. Certainly, if there are any holes large enough to host a tube socket, I'd start there.
Lou Rossi Designs
and Schematic Capture
Radio interference maybe need to add a 33k grid on the input if there isn't one. Also check grounding of the input jack.
jelle
Post by jelle »
Consider rebuilding all your grounds at the chassis level.
sepulchre
Post by sepulchre »
M Fowler wrote:Radio interference maybe need to add a 33k grid on the input if there isn't one. Also check grounding of the input jack.
Yep, 33K right on the the input pin of the tube socket worked a treat on mine with the radio problem.
Reeltarded
Post by Reeltarded »
Turn your radio off.
If the interference is getting into the grid of V1 then try a 15pf-30pf cap from the input to ground.
It will shunt radio freq to ground.
Also, make sure the 1 meg resistor on the input is connected right.
chadb
Post by chadb »
As this circuit uses both the input grids on V1 (pins 2 & 7), should I add a 33K resistor to both grids or just one?
Solder a 33k resistor on each tube pin (2 & 7).
chadb
Post by chadb »
Thanks! I'll give it a try. In theory though, I still don't quite understand how this will make a difference. On say a TW Express that does not have an input grid resistor this makes sense, but since the superlead has two 68K grid resistors and when you plug into one input the value is approximately 33-34K already. I don't see how adding another 33K in series would change this. But hey, I'm not claiming to know everything.
Your right you already have 68k grids, so forget about it.
chadb
Post by chadb »
Structo wrote:If the interference is getting into the grid of V1 then try a 15pf-30pf cap from the input to ground.
If I'm not getting this interference without an input cord plugged in, or even with the wires to the grids on V1 removed, do you still think adding a small cap on the inputs would work? Or is the problem most likely somewhere else in the circuit?
