6AQ5 low power super lead started
- randalp3000
After seeing a Zep tribute band I started getting Marshall fever again. So I thought I would build a low power small amp for fun.
Here is what I have so far and about to start the layout and chassis punch.
If it turns out good I might do one with 4 6aq5's to gig with.
Re: 6AQ5 low power super lead started
It should work out well for Ya and those Q5s pretty much need the same drive signal voltage as a 34 would!
- randalp3000
Time to get started
edit, updated layout
I have long thought about such a thing. Can't wait to see what you get.
- randalp3000
Progress
Come on, start out with 4X 6AQ5 otherwise it's not a Super Lead. In honor of Spike Jones you ought to call a 4X 6AQ5 version a Super-Duper Super Lead.
You can always pull 2 tubes if the cops keep coming over
- randalp3000
Done for today
- randalp3000
More progress
Looks great!
What's your plan for voltages, to keep the tail end low and the front end high or at least plexi-like?
- randalp3000
jelle, thank you
rp
I found a voltage chart online yesterday and I run the B+ in parallel for the preamp so I have a bit more control. After I get it running I'll tweak the dropping resistors to get it in marshall territory.
I hope to be using it in church this Sunday.
rp
- randalp3000
It lives...........
had to switch the OP trans primary's and tweak the preamp voltages a bit. Hope to be able to crank it up today and see how it holds up.
- randalp3000
Here's the updated schematic.
This amp rips, can't wait to use it this weekend.
- randalp3000
Here's a gut shot
