Eh, so I will do the sound bites on Thursday. Sorry about that to anyone who was waiting. I'll do it.
I don't agree. the larmar can be implemented without any extra lead length. indeed, you can even shorten the leads in a plexi (although it wont matter much). I haven't experienced any problems with a good cable. if you use a cable with much capacitance you need to reduce the 47pf fizz cap a little.JamesHealey wrote:The LarMar PPIMV doesn't sound as good as non-mv even when totally cranked so it's 220.. there is some kind of blurring to the tone that I can't describe probably due to the shielded cables and extra lead length.
I really hear this difference and do not like the LarMar because of it, It's deffinately the most transparent MV I've ever tried though.
I actually like the way it reduces negative feedback as the master is turned down. Another variable in the sonic palette.funkmeblue wrote:what about it's effects on the negative feedback loop? That's what has always put me off trying this master on an express. Works great on my cathode biased zero negative feedback amps, better than my airbrake.
You will find, however, Larry saying that he does not use this master volume himself.If you go to the Metroamp forum you can read 82 pages of posts and not find one bad reaction to the LaMar PPIMV. Eh?
