Just put 6L6's in my D'Lite
Re: Just put 6L6's in my D'Lite
I like it. I'd like to A/B it with the 6L6's but this is what life is about, a clean windshield, a tank of gasoline, Dumble in the backline, and a show shine.
Wow! I gotta' try the 6L6s. You nailed the "Robben" sound.
ampdoc
ampdoc
WOW! playing and sound are really nice!
Thanks for the compliments guys! I have since discovered that, after changing from 6V6 to 6L6's, the impedance changes. So with my 8 ohm cab I needed to run the switch at 16. Sounds even better now! More headroom and louder.
Well you got me thinking(dangerous). I am using a Hot rod Dekuxe OPT which is a 6l6 amp. I am running 6v6s. Should I be running an 8 ohm load on the 4 ohm tap?
yesBuschman wrote:Should I be running an 8 ohm load on the 4 ohm tap?
Greetings,
Isn't this correct:
Note about 2x6L6 valves: With the standard 2x6V6 setup, the primary OT impendance is 8k Ohm and secondaries are 4, 8 and 16 Ohm. However, if one uses 2x6L6, the primary impendance should be 4k Ohm, so by loading the 8 Ohm secondary wiring with a 4 ohm cabinet, the "reflected" impedance of the 8k Ohm primary becomes 4k Ohm.
Isn't this correct:
In my 5 years of intense daily tinkering with this type of circuit, there is nothing better sounding to MY ears about a 6V6 poweer section. For ME, 6L6 is more than just a little better. Get a beefy output tranny and a set of 6L6 tubes. Far superior.... Just my 2C
Dogears, I agree. I found that EL34s were too grainy for my Sano/dumblelite version, and the 6V6s didn't have the 6L6 full sound. Plus the impedance was way off with only an 8 Ohm tap. The feedback values were changed to 8.2K/1k.
This amp sounds best with a set of RCA 6L6GCs driving the original 15" alnico Jensen. The original sano design used a pair of 6L6s.
Has anyone tried a single 15" spkr with the dumblelite? I personally like the 15" tone, compared to bassman type 2 10" or 2 12" enclosures. Although I may be mixing apples and oranges here, since the 2 10 enclosure is loaded w/jensens, and the 2 12 enclosure is loaded with JBLs.
BobW,
heisthl built an interesting non-HRM amp with a single 15 JBL that is chronicled here: http://ampgarage.com/forum/viewtopic.php?t=2370
He raves about the overtones that jump from that chrome dome 15" speaker. I have yet to hear it in person but, trust his opinion of it. It is, I believe, 2 clean channels - 2 x 6L6 output.
Has anyone tried a combination of a 6L6 and an EL34?
My amp has a dual bias circuit so i might as well use it.
Will let you know...
Ed
Ed
thanks for the info stelligan. Mine is a different animal, basically a top loaded 6L6 dumblelite w/PAB and OD relays.heisthl built an interesting non-HRM amp with a single 15 JBL that is chronicled here: http://ampgarage.com/forum/viewtopic.php?t=2370
btw, the voltage doubler circuit (using 100uFs) is enough to drive two relays (40mA each) and LED indicators (15mA each). Although the voltage drops to 9.5 VDC w/ both LEDs and relays on, the relay pickup voltage is at 9.1 VDC.
Using the 1.2A Radio Shack 12.6V xfmr and a regular bridge rectifier topology I can power 3 12V relays simultaneously and the regulated voltage stays locked at 11.94V (7812 regulated). I have to wait to get the 5-pin XLR cable to test the 3 LEDs also.BobW wrote:btw, the voltage doubler circuit (using 100uFs) is enough to drive two relays (40mA each) and LED indicators (15mA each). Although the voltage drops to 9.5 VDC w/ both LEDs and relays on, the relay pickup voltage is at 9.1 VDC.
If you have the same xfmr there is no reason to use the doubler, IMHO.
Wife: How many amps do you need?
Me: Just one more...
