Monkeymatic Shasta Princeton Reverb pine combo
Fender Amp Discussion
mhartman
Re: Monkeymatic Shasta Princeton Reverb pine combo
Post by mhartman »
xtian wrote:I dovetailed and glued up my cabinet.
Wondering about the baffle, specifically the material, like Fender silver fabric, on the front of the baffle. Is the material just resting against the surface of the baffle? Or do you build a frame to suspend it?
I ask because I had an old Sano once where the material on the cabinet was actually rattling. The glue had dried out.
The material is just resting on the wood baffle. It is just wrapped around and stapled on all sides.
Firestorm
Post by Firestorm »
Fender did it both ways depending on the year: earlier blackfaces had the grille cloth right on the baffle; '68-'69 or so, most models had a thin frame around the edge of the baffle to hold the cloth away.
This was my first time cutting the three-degree angle on the front of a combo, Fender style. I have a cheap Harbor Freight angle tool for the table saw. Worked great! Nothing like seeing five or six inches of unprotected table saw blade spinning away. Came away with all my digits, tho.
I can tell by the smell this cab is going to sound good.
Colossal
Post by Colossal »
That looks really nice Aaron, great job. Bet it smells good too!
rdjones
Post by rdjones »
If you want a nice smelling cab try Cedar.
Of course you don't want to go and hide the aroma by covering it with nitro or worse Tolex.
Problem is getting boards wide enough to fit anything but the smallest chassis.
Someone want to make me a Cedar cab ?
(I don't do woodwork ...)
rd
You did a great job building that cabinet.
cbass
Post by cbass »
Cabinet looks great good job
rdjones wrote:If you want a nice smelling cab try Cedar.
rd
You mean juniper aromatic cedar its not a cedar at all its a juniper
I built a smellycaster out of some.its pretty rough built with basic handtoolsvand no internet
Boards can be glued together together.its rare but I've seen some boards over 12 " that are completely clear.takes bout. A thousand years to grow a tree like that
Western cedar makes me sneeze
http://ampgarage.com/forum/download/file.php?id=23076
You'd think this would be easy to Google: how large a hole for a 12" speaker? In the baffle, I mean.
I'm finding 11.125" dia. Sound right?
xtian wrote:I'm finding 11.125" dia. Sound right?
Now I measured my existing box at 10 + 13/16.
rdjones
Post by rdjones »
JD Newell 1x12 combo - 10.5"
MusicMan 1x12 combo - 10.75"
1980 Deluxe Reverb - 10 5/8"
Inside diameter of the gasket on several different 12" Fender speakers - 11"
It doesn't seem too consistent (or critical), just match it to your speaker's gasket I.D.
edit: EV SRO12 - 11", EVM12 - 10 7/8"
rd
It's so good to go build something with my hands, instead of pushing pixels. My mood has improved. Thanks y'all for the encouragement!
Thanks, Bob! Settled on 11.125, and it ended up fitting the Celestion Blue perfectly.
The T-bolts are nice, but I'll have to countersink them so they don't show thru the grille cloth.
Looks great don't forget to paint inside panels and speaker baffle flat black before tolexing. Or at least paint the baffle board flat black.
Thx Mark. This cab is staying blonde. Gun oil finish, wheat grille and cream knobs. It's super smooth from lots of sanding.
lord preset
Post by lord preset »
xtian wrote:Thx Mark. This cab is staying blonde. Gun oil finish, wheat grille and cream knobs. It's super smooth from lots of sanding.
The cabinet will look great with an oil finish but if you don't paint the front of the speaker baffle black the speaker cone will show through the grill cloth. Probably not the look you are after.
