Nothing extraordinary here except that the amp, as I am sure, all know sounds absolutely amazing
Didn't have any troubles with the excellent layout (that I had to flip as usual, because of the chassis source I am using - Europe is limited in this respect and the chassis I am using has the power input hole pre-punched on the wrong side sort of).
I am using Tung Sol RI 12AX7 at V1 and Sovtek's 12AX7 LPS for V2 and V3. JJ EL34s as power tubes. I will run through few other power tube sets, I have around - 6L6, 5881 and 6CA7, once the initial excitement cools down - just can't believe it can sound any better than now
Another find with this build is an excellent European transformers manufacturer - InMadOut - I sent out the specs and couple of weeks later I had the transformers received and they hit the specs at the plates within 1 volt! Solid and nice looking iron.
Couple of quick recordings, just enjoying touch responsiveness and using the guitar volume like never before
http://soundcloud.com/synchu/synchus-ma ... -impromptu
http://soundcloud.com/synchu/synchus-mars-demos-2
Couple of mods I will try most probably will be some sort of switchable Master Volume or Power Scaling and Mark Knopfler mod.
I called it Mars.
Niki
