Ok, you're probably right about that resistorMatec wrote:Arjepsen
Every time the signal leaves the motherboard, and goes to toneboard, all DC component is filtered. It would not be the case this first stage, but got anyway. As there Littlewyan said other filter formed of such C15 / R36, and JCM1 plus one, formed by C16 / R24.
I suppose that the signals with DC components,, not combine with these connectors, and cause noise, maybe ...
About these "floating" circuit.
They are a type of connection, the circuit ground with the chassis ground. I do not know exactly what the advantage of this way of making that connection. But it was common in Malhalls 90s and 2000s.
Matec
![Smile :-)](./images/smilies/icon_smile.gif)
The reason I mentioned to floating circuits, are that they can be confusing.
I had to read through this thread when I first built the amp, to figure out what it was. With the recent development I came back to edit my amp, and looked at the new schematics, and couldn't remember what those were.
My suggestion is to make the schematic less confusing to someone like me, seeing it for the first time
Btw, I wonder if they might be some sort of hum reduction effort?
