Dumbleator Layout
norburybrook
Re: Dumbleator Layout
Post by norburybrook »
Having just followed this layout, there is an error on the first two radial electrolytic caps, the polarity is the wrong way round. Exploding electrolytics aren't what you want at the end of a build :)
Marcus
jam-mill
Post by jam-mill »
norburybrook wrote:Having just followed this layout, there is an error on the first two radial electrolytic caps, the polarity is the wrong way round. Exploding electrolytics aren't what you want at the end of a build :)
Marcus
Building to the attached layout works fine and seems to be similar to what was originally posted here. So, I'm not so sure there is a layout error.
John 15:12-13
norburybrook
wish I'd seen that one first :D
check the very first post in this thread, first picture.
I always expect the original head of a thread to be the one with the most up to date layout.
Marcus
jam-mill
Post by jam-mill »
norburybrook wrote:wish I'd seen that one first :D
Marcus
I've found that careful scrutiny of all information presented here is required.
John 15:12-13
bluesfendermanblues
Post by bluesfendermanblues »
Never really understood why using a xformer with too little secondary voltage, anayway. Alternatively use two small cheap print xformers with the two secondary sides connected.
I use a 230v (in EU that is) primary with 12 volt secondary => into a 6 volt secondary of the 2nd xformer and get (almost) the double voltage on the primary, like 300volt. Besides feeding the 2nd transformer, the 12 volt ac secondary of the first transformer is used as heater voltage for the 12ax7.
xenrelic
Post by xenrelic »
Here's the Triad R-2C power transformer spec sheet with dimensions for the Dumblelator.
Thanks for the Data sheet very nice.
Here is a photo of box and transformer
New Clator layout using PCB
Chris Brown
Re: jacks
Post by Chris Brown »
angelodp wrote: Mon Nov 24, 2014 3:31 am Chris, in you version of the Dlator, it appears that you are grounding the jacks at the sleeve through their connection to the chassis. Some builds have discussed isolating the jacks. Have you had any issues your way…loop hum?
Ange
It's quite a while later but in case anyone wanders across this in the future, I did use isolated jacks.
▶ YouTube: BirdsnakeBrown
▶ Instagram: BirdsnakeBrown
angelodp
Post by angelodp »
Hi, sorry if this is a dead horse, I am wondering if anyone has built the series/parallel unit as shown by Structo? I there any confirmation that the layout works?
Best A
Member Klaus has posted a Boogie serial-parallel solution using just a 25k pot. You might check into that. https://ampgarage.com/forum/viewtopic.php?f=5&t=21205
I built a Dumblelater using Structo's instructions (using stand-a-lone reverb PT) first and that works very well. Not the series-parallel one.
The 2nd unit I built from Ceriatone's version which also works well.
Goldhedge
Post by Goldhedge »
Just curious if there's a BOM for this Dumbleator?
I looked around and don't seem to find one.
TIA
“The greatest energy of movement will be obtained when synchronism is maintained between the pump impulses and the natural oscillations of the system.” Tesla
talbany
Post by talbany »
norburybrook wrote: Wed Feb 11, 2015 5:06 pm wish I'd seen that one first :D
Marcus
Marcus
Sorry the original layout was not updated and what you expected. :lol:
norburybrook
talbany wrote: Thu Jun 06, 2019 12:18 am
Marcus
Marcus
Tony,
That's an old post resurrection :D
Funnily enough I've got a box here with a dumbleator in it ready to be made so you must have some sort of voodoo powers of intuition going on! :D
M
