Octal based Express
fusionbear
Octal based Express
Post by fusionbear »
Learning to learn...
Colossal
Re: Octal based Express
Post by Colossal »
Hi Carl,
Didn't you already post this one?
http://ampgarage.com/forum/viewtopic.ph ... ht=express
Cool to see it again though. It sounded really good.
fusionbear
Colossal wrote:Hi Carl,
Thanks, I haven't been around and I forgot..... Doh! I will use the search engine next time....
But, the tone stack values changed drastically from the last thread. Also, the PI couplers went from .1's to .039's. Also added a cut control.
I also removed 50 uf of filtering on the screen grids. So now the filtering is:
50 uf, 50 uf, 50 uf, 22uf. 22uf, 22uf, 22uf. Yes, that is 7 B+ steps in this little beasty...
TUBEDUDE
Post by TUBEDUDE »
Sous phenomenal! The Dist tones are great, and the cleans are glorious.
10thTx
Post by 10thTx »
That is a very nice sounding amp! Great playing also.
Thanks for sharing! With respect, 10thtx
SilverFox
Nice Sounding Amp
Post by SilverFox »
Do you have a schematic of the changes? This Rocks! I really like your builds and videos.
Just looked at the original post and saw the TS is from Merlins Book. I think I like this better than the Naylor SD clones.
silverfox.
fusionbear
Re: Nice Sounding Amp
SilverFox wrote:Do you have a schematic of the changes? This Rocks! I really like your builds and videos.
silverfox.
fusionbear
The schematic posted above is the latest. I think it is now where it should be. I went back to the .027 as the first coupler and .1's on the PI to power tubes. I separated the cathodes in the power section and added 1 Ohm resistors so I can check the current that way too. I was playing it again today and it flat out sounds amazing. I got a pair of ANOS TungSol 6550's and they sound amazing! The tubes are: V1-Modern Tungsol Reissue 6SL7, V2-NOS TungSol, V3-NOS GE, V4-5 ANOS Tungsol 6550's. BTW, ignore the 65' JTM45 in the background...
[IMG:1024:768]http://i169.photobucket.com/albums/u223/fusionbear/SD20%20Build/KIMG0037_zpssdjh4kn2.jpg[/img]
[IMG:1024:768]http://i169.photobucket.com/albums/u223/fusionbear/SD20%20Build/KIMG0033_zps2qszew8b.jpg[/img]
[IMG:1024:768]http://i169.photobucket.com/albums/u223/fusionbear/SD20%20Build/KIMG0045_zps0cnbzyfj.jpg[/img] :wink: :wink:
Thanks for the schematic. The power tube control and screen grids may need swapping around on it :!:
Someone is having too much fun!
fusionbear
pdf64 wrote:Thanks for the schematic. The power tube control and screen grids may need swapping around on it :!:
Doh! Will correct. Also, I neglected to write the value of the PPIMV dual pot. 250K A. I used a PEC.
What led you to choose to put the master pots 'backwards, 5e3 style?
fusionbear
pdf64 wrote:What led you to choose to put the master pots 'backwards, 5e3 style?
Because it is cathode biased, the pots are the 250K reference to ground. A typical cathode biased circuit has 220K's to ground. 250k is close enough.
10thTx
Post by 10thTx »
Reposted schematic after FusionBear reviewed it
fusionbear
Wow, that looks much nicer than my scribbles....
First, the last two B+ strings in the preamp all have 1.5k 3 watt resistors.
Second, the 120K on the grid of V2 is not on a switch, it is always connected to ground. There is so much gain available, if you took off that resistor, you would immediately go into grid overload.
Third, there is no 220pf between the cathode and plate on V2a.
Fourth, the coupler between V2a and the grid of V2b is a 2200pf or .0022uf.
Fifth, the cathodes of V3 are connected to a 75 ohm resistor.
Sixth, the PPIMV pot is wired backwards like a 5E3 so that the .1 couplers feed the wipers. This way there is always a 250k reference to ground through the pots.
Seventh, the cut capacitor is a 390pf, not a 500pf.
Eighth, the power tubes can be either 6L6gc's or 6550's with the 3.6k primary Classictone transformer. I would use a TW style 8k primary if I were to use KT66's. Currently, I am running a pair of ANOS TungSol 6550A's and they sound awesome!
Ninth, I don't have a 220k across the B1+ cap to ground. All the caps are rated for 500+
Tenth, the Hammond PT I used has a 5V tap that I use for the lamp and there is a center tap for the filaments. Also, you only need two diodes per ac feed from the HV.
Eleventh, the OT has 4, 8, and 16 Ohm outputs.
Grounding Scheme:
Point 1 is on one of the mounting screws of V1. I have the input jack, Cathodes, ground of the B6+ cap, and filament center tap grounded there.
Point 2 is on one of the mounting screws of V2. I have the cathodes, B5-B4 grounds of B+ caps grounded there.
Point 3 is on one of the mounting screws off V3. I have the OT, speaker jacks, B3, PI Cathode, PPIMV grounded there.
Point 4 is on one of the mounting screws of the second can cap. I have the V4-V5 cathodes, both can caps, and the HT center tap grounded there.
Point 5 Is near the input of the power cable and is the chassis ground.
I have learned so much here, I hope this is a helpful little grain of sand contribution to the rest of you. This is honestly the best OD amp I have ever built....
Colossal
Post by Colossal »
fusionbear wrote:Fifth, the cathodes of V3 are connected to a 75 ohm resistor.
FB,
Is that really a 75R resistor or 750R?
Thanks.
