test pictures
Chris G
test pictures
Post by Chris G »
[/img]Image
Here are the 3 different Output's I have (Left) 4200 (ac30) output/heyboer
(middle) 5200Heyboer, Right 6600 Heyboer all 30-35 watts.
Ley me know if this works!!!!
Chris :D
Chris G
Re: test pictures
Post by Chris G »
Image[/img]
Here's my liverpool clone
Chris G
Re: test pictures
Post by Chris G »
Image[/img]
The cab it's going in.
Chris G
Re: test pictures
Post by Chris G »
Image[/img]
liverpool back
Lovely work Chris!
Post by Mark »
Dear Chris
The Liverpool amp looks great!
One question though, what is the measurement of the lamination on the front of the amp?
I thought the lamination was the same size and the height of the chassis. Of course I could be wrong. :cry:
Mark Abbott.
Omar
Re: test pictures
Post by Omar »
Chris
That looks awesome!!! :D
How about some internal shots?
Any clips?
Did you build it using the schematics in the Files section?
Omar
Tone by misadventure
Chris G
Re: Lovely work Chris!
Post by Chris G »
Mark wrote:Dear Chris
Mark Abbott.
Hi Mark,
Thank-you!!!!! the measurements are 2-3/4" x 19",I don't know if this is exact as my cabs are slightly larger than a standard wreck, I think.......If you look at some of the photo's on-line it appears from the back that the front face slides into a track on the front panel ,making the face plate bigger than the chassis,anyway the cabs were built about 2 years ago.......long before you and Matt T. did all the leg work on the great info we now have!!!!! :D
Thank-you Mark!!!!
Chris
Chris G
Re: test pictures
Post by Chris G »
Omar wrote:Chris
Any clips?
Omar
Thank-you Omar!!!!!!!
I do have an internal shot to post will try later to up-load
No clips of either amp at the moment :(
All the work ,with the exception of the cab and face plate was done with info gathered by Mark Abbott and Matt Taylor... :D All contained here on our site!!!!!!
Thank-you!!!!
Chris
snide
amp
Post by snide »
Chris,
Very nice looking amp. I bet it sounds as good as it looks.
Eric
Chris G
Re: amp
Post by Chris G »
snide wrote:Chris,
Eric
Hi Eric,
Thanks very much!!!!!! It sounds pretty good at this point!!!! :)
Thanks!!
CHRIS
Chris G
Re: test pictures
Post by Chris G »
Omar wrote:Chris
Any clips?
Omar
HI Omar,
Heres a shot of the inside!!!
Chris
Mike
Re: test pictures
Post by Mike »
That looks great~!! One question: how did you join the corners?? Did you just use a 45 and glue or did you biscuit join or ??
Thanks a lot~!! Good job~!!!
Mike
Chris G
Re: test pictures
Post by Chris G »
Mike wrote:That looks great~!! One question: how did you join the corners?? Did you just use a 45 and glue or did you biscuit join or ??
Mike
HI Mike,
Thank-you !!!! The cabs were biscuited.
Chris
