Ods combo
Ods combo
There is a first for everything. After building 10 amps and done none of the cabinetry myself, this is the first.
Bought a new car, oldest daughter going to university, wife and other daughter want holiday, this is going to be a low budget cab.
Wood is engineered timber(pine I think).
The sides are going to be glued and screwed.
Sides are almost ready.
Any suggestions? I'm a newbie on this, you can't offend my woodskills because I basically got none.
Erwin
Erwin
- Colossal
Re: Ods combo
Well, you are off to a good start so far!
Re: Ods combo
Advice. Watch your fingers!!!
Looks good. Tolex cures all sorts of ills.
Re: Ods combo
Looks great Erwin! One thing I discovered after making a bunch of cabs is that I like the edges rounded more . I use to sand the 1/2 round over by hand by that took for ever, then I got a router and that made things much easier!
Its all personal taste anyway.
Congrats on your first cab and I am sure the bug will bite and there will be many more!
Cheers!
Guy
Cheers!
Guy
- norburybrook
Re: Ods combo
way to go Erwin
as cabinet/woodworking goes, speakers/combo's are very simple 'boxes' really.
make sure you leave enough room on front baffles/rear panels etc for your tolex and grill cloth/pipping.
screwing and gluing is fine, just countersink your screws and fill then sand smooth, then route edges.
make sure you sand down the corners properly or your metal corners wont fit
Tolex will cover a multitude of sins as mentioned above, however it's a skill in itself is Tolexing. I'd recommend using water based glue it's a lot easier to apply and is quite forgiving.
Re: Ods combo
Thanks guys for all info!
Alkuz shared some tips with pics which made me want to do the edges with a router.
I asked around to borrow a router from local friends, and got lucky someone nearby has one.
A very well known dutch overdrive special builder has a batch of very cheap tweed tolex and matching grillcloth, local webshops asked double to triple the price he offered them for. Easy deal.
Marcus: what tolerances in mm do you keep on the panels with tweed tolex and grillcloth?
The local hardware stores offer a limited run of brands on the glue: mostly Bison and Pattex and I absoluteley have no idea which one to use from these brands except for the woodglue.
I bought tolexglue: servisol 120 which was advertised from a webshop with guitar amp parts.
If any of you have good dutch available glues for this let me know.
- norburybrook
Re: Ods combo
Erwin, I've never done tweed I've done suede though which I suppose is the same thing/technique. I'd say 1mm each side for tolex on the sides and 1mm or the grill cloth and an extra 1mm for pipping so that's 6mm plus some wiggle room as well. It can be hard to gauge at times but if you don't allow enough then you're into pulling grill cloth,pipping off and sanding/sawing/planing the baffle down to fit.erwin_ve wrote: ↑Tue Jul 23, 2019 3:38 pm Thanks guys for all info!
M
- norburybrook
Re: Ods combo
if you're using hand tools like I do then you can't be that tight with tolerances as you'll find your cut's wont be 100% straight and the angles wont be 100% either so you need some 'wiggle room'
If you have table saw's etc and can cut perfectly it means you can work to tighter tolerances.
there is a wonderful sense of satisfaction though when you've made it all yourself, so I'd say it's worth the slight imperfections
M
Re: Ods combo
Hi Marcus
Yes, I have a lot of different tools. But these are normal tools for hobbie and DIY. And I use a variety of snap-ins, which helps to do accurately and smoothly
It is important to use each tool to achieve the best result. In order to make a hole for the speaker, you can use an electric jigsaw. And the edge of the hole will be a little wavy. But if you use a router this hole will be perfect.
And the slot for the amplifier panel can be cut by the electric jigsaw as well. But if you use a template and a router, the result will be much better.
- norburybrook
Re: Ods combo
that's a whole different level from my 'Ghetto' cab builds you have a garage!!!!!
one of the downsides of living in a big Expensive Capitol city...lack of SPACE........
M
M
Re: Ods combo
Marcus, unfortunately this is not my garage((( This is my friend's car service and he lets me work on the weekend.norburybrook wrote: ↑Wed Jul 24, 2019 10:31 am that's a whole different level from my 'Ghetto' cab builds you have a garage!!!!!
M
But I'm talking about something else - the quality of work should not depend on the place. The quality depends on properly selected technology and instruments
- norburybrook
Re: Ods combo
true, you have good tools though, a rail saw, router with jigs for joints, clamps etc i don't have that stuff I made my first cabinet with a jig saw and and electric drill/screwdriver , i sanded my edges round..took foreveralkuz1961 wrote: ↑Wed Jul 24, 2019 12:18 pmMarcus, unfortunately this is not my garage((( This is my friend's car service and he lets me work on the weekend.norburybrook wrote: ↑Wed Jul 24, 2019 10:31 am that's a whole different level from my 'Ghetto' cab builds you have a garage!!!!!
M
nice dog in your avatar
it's 36 degrees here in London today..here's my dog in the studio with me in the air con
M
Re: Ods combo
That's the best place to be on a hot day, in Marcus's A/C studio with some great guitars and amps!
Re: Ods combo
I was outside today working on the cab with 38,5C (101F). Im soaked
Made the sides with wooden dowels, everything fits well. Waiting on the router from a friend.
Tools used sofar: Jigsaw, grater, sander, ruler, drill and dowel mold.
My dog was inside in front of the fan.
