2204 chassis deminsions
- dragonbat13
Does anybody have any chassis deminsions or blueprint for the 2204? Specifically the bat switch type faceplate?
Re: 2204 chassis deminsions
The chassis that Mojotone sells measures 27 inches wide by 6.5 inches deep by 2.5 inches high (686 x 165 x 63.5 mm). They say on their website that those are the original Marshall 2204 chassis dimensions. If you do a Google search you will see the dimensions on the Google search preview, but if you go to the website the dimensions are not published.
I have seen others post the same dimensions for ones they've built.
https://www.mojotone.com/British-800-St ... -Faceplate
- dragonbat13
I'm looking for the faceplate measurements, the locations to drill the holes.
My build is gonna most likely use the mojotone 18 watt/jtm blank chassis.
https://www.mojotone.com/Undrilled-Aluminum-Chassis
I want to put that into a small box head cab. I'm using AA Electronics PCB and JCM800/2204 stand up iron from amp parts direct.
I want to fit the pots in the correct place on the chassis so they will look correct when installed in the small box head.
I'm planning on etching a faceplate from aluminum or possibly brass, so I gotta be able to print out an etching mask.
I hope it will be useful
- dragonbat13
alkuz I appreciate that. I can make that work. I'm not going for vintage correct, just wanting it to fit.
If I were to remove two of the input jacks on that drawing and recenter the rest accordingly, would that center the controls in the opening of an 18 watt head cabinet?
- Reeltarded
Valvestorm
It's metal. It's drilled. It's cheap. Marshall just put plates that covered unused holes on their amps.
- dragonbat13
I knew there was some place I had seen what I wanted.
Come on payday!
Come on payday!
- dragonbat13
Well I bought the chassis and faceplate.
One thing I'm concerned about is the fact I bought the Heyboer APD-8032H choke.
The APD-8023H power transformer and APD 8025A-H output transformer also.
Im hoping the four hole choke is a good choice. I will have to drill to mount it.
I'm gonna start a build thread or change my other thread. I'm gonna need help on this one. I have ZERO marshall experience. Never even owned one. Hence the reason for building it.
This is the old Metroamp layout that I used for my 2204. This should help you along with your build.
https://drive.google.com/drive/folders/ ... jBAObvpf2g
These are some of the other Metro layouts that one of the members saved,
https://drive.google.com/drive/folders/ ... 549g-K1iDA
- Reeltarded
5h choke is good to go.
How is it going with the build? Curious to see my PCB in actiondragonbat13 wrote: ↑Sun Jan 15, 2023 3:13 pm I'm looking for the faceplate measurements, the locations to drill the holes.
Cheer from London,
Andrea
AA Electronics
