Dumble Preamp (for SE amp)
- Kagliostro
I would like to plan an SE amp using a GU50 (or 1625 as Power Tube)
Please can you point me to an ODS version that has good documentation to plagiarize the preamp schem and Layout part
There are so many versions of schematics and Layout that I'm a bit confused
Many Thanks
K
Many Thanks
K
Re: Dumble Preamp (for SE amp)
Ciao Kagliostro. This SE ODS version was a huge hit.Kagliostro wrote: ↑Fri Mar 31, 2023 7:29 pm I would like to plan a SE amp using a GU50 (or 1625 as Power Tube)
Many Thanks
K
https://ampgarage.com/forum/files/mts_mini_hrm_190.pdf
Special thanks to Colossal for the schematic
This is my 777 post do I win the jackpot LOL!
Cheers
Gaetano (Guy)
- Reeltarded
2 others liked this
- Kagliostro
Thanks Guy77
Is there a version of Layout I can use
I'm interested also if it is only about the preamp or a whole amp Layout from which I can borrow the preamp layout
Ooops ... Sorry Reeltarded
K
K
Truly game over.
Kagliostro wrote: ↑Fri Mar 31, 2023 10:07 pm Thanks Guy77
K
I won a chicken and its cooked! I needed a good laugh today and this did the trick! Thanks Reeltarded and Kagliostro!
Here is the link to the full post Kagliostro. Page 2 has a layout you can use.
https://ampgarage.com/forum/viewtopic.p ... rm&start=0
Cheers
Guy
- Kagliostro
Ciao Guy77
![Image](https://ampgarage.com/forum/download/file.php?id=11726&mode=view)
and a link to a pdf containing one other schematic
https://ampgarage.com/forum/download/file.php?id=11902
but I'm looking for a Preamp Layout
K
Unfortunately on that page I can see only a Schematic
K
Page 3?
- Kagliostro
Ciao Martin
Seems that something is at page 5
a Mini HRM Schem & Layout from 10thnx (I think he is Tubenit)
![Image](https://ampgarage.com/forum/download/file.php?id=11795&mode=view)
![Image](https://ampgarage.com/forum/download/file.php?id=11793&mode=view)
Franco
Franco
Yes, sorry.
- Kagliostro
I'm quikly reading that thread and I've find something that is not favourable to me
https://ampgarage.com/forum/viewtopic.p ... 09#p120509
That preamp has not enough swing for a tube as 5881 and so I think the same for the GU50 or 1625 tubes
EL84 is in the order of 11.3mA/V, 1625 is around 6mA/V and GU50 only 3-5.5mA/V
may be a 6AV6 tube is to be inserted between the Preamp and the Power Tube if the Power Tube has a "low" mA/V rate
Franco
Franco
Is anyone else curious about potential troubleKagliostro wrote: ↑Sat Apr 01, 2023 3:54 pm Ciao Martin
Franco
With the efx loop(breakout jacks) return feeding directly into the power tube without an internal grid ground reference? Or am I just overly pessimistic?
TUBEDUDE wrote: ↑Sat Apr 01, 2023 8:46 pmIs anyone else curious about potential troubleKagliostro wrote: ↑Sat Apr 01, 2023 3:54 pm Ciao Martin
Franco
With the efx loop(breakout jacks) return feeding directly into the power tube without an internal grid ground reference or capacitive coupling? Or am I just overly pessimistic?
I agree, I'd like a grid leak resistance there too.
- Kagliostro
Switched pots used as grid leak resistor ?
Franco
Franco
