Sir 36 mod
Sir 36 mod
Hi Guys, so after all these years i finally found out what the real 36 mod was, here is a clip of how it sounds in the room.
https://youtu.be/uIdybOVtRYo?si=apBWjAR_Q7uQnhMf
Cheers.
Cheers.
- dorrisant
Re: Sir 36 mod
Sounds pretty good. Sounds more like 39 than 36. The speakers make a huge difference to the tone as well.
Even though I REALLY don't dig that circuit for anything other than Slash (and I am kinda played out with that), I have done a ton of clip-listening. Are you using Greenbacks or G12-80s?
Re: Sir 36 mod
Yep, the 39 and 36 are almost the same, i just used v30 on this clip, they seem to sound the best. You could also use G12M.dorrisant wrote: ↑Tue Feb 27, 2024 2:00 pm Sounds pretty good. Sounds more like 39 than 36. The speakers make a huge difference to the tone as well.
Re: Sir 36 mod
https://youtu.be/tXk0UKBllXs?si=MtY5jwp6pdhXI4-n
https://youtu.be/LYPZQkZ0ois?si=_XnzbON4mo6yNsI3
https://youtu.be/l4T4EoWXPcc?si=fjtcTV6KlbjvgwJl
Some more clips. btw i haven't done any post eq.
I know this 36 thing has been done to death, but i thought i would let you guys know.
Re: Sir 36 mod
and again, what this is doing in diy forum? you are sharing? or only propaganda?dukeamps wrote: ↑Tue Feb 27, 2024 12:39 pm Hi Guys, so after all these years i finally found out what the real 36 mod was, here is a clip of how it sounds in the room.
Cheers.
Re: Sir 36 mod
Well just start off with a 34 mod and add a 10k stage and you are good to go.
Re: Sir 36 mod
Also get some v30 or g12m speakers.
Re: Sir 36 mod
Years ago I followed some of the many SIR #36 schematics you posted (on another forum) and built many similar amps, usually 50 watt
These heads were sold to musicians in my local area and were well received --- your schematics helped me to learn to modify Marshall circuits
But most local musicians, at the time, were into Death Metal and they called these amps "mere Thrash Amps" --- they didn't feel that the SIR #34, 36, 39 amps were heavy enough for them
So I went on and built more aggressive circuits in 100 and 150 watt versions (also some channel switchers) for this crowd
Now I've come full circle and I've been doing some amp work for a guy who plays drums for several touring Doom Metal bands (I've seen a vid of him playing on Rock Palast, the German TV show)
He's been running a pro backline rental business, in the USA, for several years and I've been fixing up some of their rental amps that have broken down (mostly beat-up old JCM800's)
I'm currently re-building a JCM800 SuperBass that they want to be a stock 2203 circuit
These people want stock spec JCM800 2203 and 2204 amps --- they get up on stage and turn these amps up all the way (or nearly) ---- they like Poweramp Distortion and couldn't care less about increased Preamp Distortion or low volume tone/sound
Running these 2204/2203 stock spec amps at High Volumes has changed the way I look at them
A 2204/2203 amp doesn't really need mods/increased Preamp Distortion if you can just turn it up far enough and push the Power section into clipping
Re: Sir 36 mod
Good jobgldtp99 wrote: ↑Sun Mar 03, 2024 1:03 am Years ago I followed some of the many SIR #36 schematics you posted (on another forum) and built many similar amps, usually 50 watt
