Raspy treble from 2203 amp
Marshall Amp Discussion
Post by Mark »
I plugged into my friends 2203 and it sounded dreadful. It was overly compressed and the treble is raspy.
The compression was due to the 100K cathode follower resistor measuring 880K. I replaced it and the amp sounded much better. The amp still has raspiness which goes away when I turn the volume up.
I’m wondering if I should consider the Kevin O’Conner mod where you put a 100K resistor in series with the master volume wiper connection.
http://site.triodestore.com/JCM8002203Stock.pdf
This Triode circuit diagram has a 100pF cap across the first stage and I believe that Dave Friedman does put a 0.002uF across the cathode follower 100K resistor.
Thoughts on raspy treble response?
Thanks for your assistance.
bepone
Re: Raspy treble from 2203 amp
Post by bepone »
Speaker is v30? Change the speaker?
Some other guitar problem?
Post by Mark »
bepone wrote: Sat Apr 13, 2024 1:50 pm Speaker is v30? Change the speaker?
I used a EVH MIM guitar, and I also used my Strat. The box is a Fender Bassman box with Kendrick Blackframe speakers in it. I have previously used the box with a 1959 and it sounded fine. The speakers aren’t overly bright.
Post by Mark »
Mystery double post.
Littlewyan
Post by Littlewyan »
That master volume mod doesn't actually help, I did some tests on this a few years ago with a spectrum analyser and found it made no difference. But YMMV.
Dave Friedman puts a 500pF cap across the cathode follower 100K, lowers the first coupling cap to .0022uF, adds a 22uF to the final stage cathode and lowers the NFB resistor to 47K on 4Ohm tap. This is what he did to the Jake E Lee amp anyway. If you're looking to tame the raspiness I would start with the first and last mods personally, or even try removing the second 500pf treble peaker.
cdemike
Post by cdemike »
Littlewyan wrote: Sat Apr 13, 2024 2:09 pm That master volume mod doesn't actually help, I did some tests on this a few years ago with a spectrum analyser and found it made no difference. But YMMV.
Agree with these. I also would suggest experimenting with potentially adding a resistor to ground after the second peaker (sort of simulating adjusting the normal volume control when plugged into only the bright channel on a 4-hole amp).
What was the cause of the 880K CF resistor? Was it damaged or was it a mistake? Either way, it might be worth checking other component values also to see if they might be contributing.
Post by Mark »
cdemike wrote: Sun Apr 14, 2024 8:31 pm
Thanks for taking time to reply to my thread/post.
The 100K went high over time. The 100K on the valve socket is measuring 120K so it’s going too.
I think it’s the old Fender issue where they used 1/2 watt resistors on the anode/plates of the valves when they should have used 1 watt resistors. I replaced the resistors with 1 watt ones.
