Robben Ford & His Dumble Overdrive Special
dbharris
Re: Robben Ford & His Dumble Overdrive Special
Post by dbharris »
Guy77 wrote: Mon May 13, 2024 11:26 pm Here is a video of him playing the amp live back in 1988. I believe that is his dumbleator sitting on top of it.
I noticed the amp did sounded a little darker here with the dumbleator. It still sounds amazing!!
I wonder if the ageing of the components over time also changed the sound of the amp.
https://www.youtube.com/watch?v=-YI71Tlo4cY
Cheers
G.
#102 was probably still a low plate classic then too. But RF always sounds good and apparently #102 does too!
-Dan
WhopperPlate
Post by WhopperPlate »
Cheers
G.
More like replacement components .
AFAIR 102 has had a cap job ;, original caps replaced with F&T electrolytics.
I maintain the assertion that those caps are not my cup of tea. They lend themselves to a scooped midrange , and bright and potentially grainy high end response within most amplifiers.
They feel great , and the harmonics will feel alive, but the pitfalls can be bothersome .
I certainly like the way 102 sounds back in the day more than it how sounds now
Charlie
Guy77
Post by Guy77 »
WhopperPlate wrote: Tue May 14, 2024 5:17 pm
Cheers
G.
Hi Charlie, if I had to choose the sound I liked best I would also slightly favor that recording I posted from 1988.
G
Charlie Wilson
Post by Charlie Wilson »
Cheers
G.
Ruby Gold.
CW
ayan
Post by ayan »
Nice picture, I'd never seen it before!
G.
Matt J
Post by Matt J »
Charlie Wilson wrote: Wed May 15, 2024 12:17 am
Cheers
G.
Ruby Gold.
CW
Awesome gut shot!
Are there any other confirmed internal shots of #102?
Matt J.
I see it has the pro tour option, 12 chassis mounting bolts ;^)
llemtt
Post by llemtt »
Cheers
G.
Ruby Gold.
CW
Awesome!
Rectifiers/bias board has also been updated with later version..
M.
WhopperPlate
Cheers
G.
Ruby Gold.
CW
I stand corrected on F&T, thanks CW
Weren’t the original sprague ?
Charlie
hitchcaster
Post by hitchcaster »
the layout in files says stock 60/70s twin iron but it looks different? i thought it was red knob twin/showman PT but ive never been able to figure this out. the 6v relay transformer in there is "cal-rad" . layout says its radio shack.
erwin_ve
Post by erwin_ve »
The relay transformer is a Calrad 45-728 6 Volt 1.5 Amp transformer.
PT is a export model, still unsure if its a Fender or Peavey or something else...
hitchcaster wrote: Thu Jun 13, 2024 12:07 am the layout in files says stock 60/70s twin iron but it looks different? i thought it was red knob twin/showman PT but ive never been able to figure this out. the 6v relay transformer in there is "cal-rad" . layout says its radio shack.
Not having actual gut shots, some details appear to have been copied directly from the 124 layout. Note the layout of the PS board in the 102 photo is also different.
The 022756 PT specification in the layout drawing may have been based on word that it was a Showman unit, which would be 125P34A or 022756. The export model would be 125P34AX. Of the stuff that really matters, some of it is still shrouded in silicone. Perhaps the assumptions used for the layout should have been stated clearly in the Files post.
