what caps to use in 5E3 build ?
Charlie Wilson
Re: what caps to use in 5E3 build ?
Post by Charlie Wilson »
Well you could simply look at the bottom of the Rob Deluxe layout. He has a parts list.
CW
Phil_S
Post by Phil_S »
There are inherent problems buying from a BOM, particularly when you are new at it.
1) One is the postage/shipping. You leave out one thing and it will cost an extra $10 to get that $1 part. Oh, and then it happens again. And maybe a 3rd time. You won't experience this with a kit.
2) The other is that your unpracticed eye may lead you to think that you've chosen the appropriate part(s) when, in fact, you haven't. See #1 above.
drew
Post by drew »
Are you going to buy a board from Hoffman? If so, order as many of the components as you can from him, too.
Sequimite
Post by Sequimite »
Charlie Wilson wrote: ↑Tue Oct 26, 2021 6:18 am Well you could simply look at the bottom of the Rob Deluxe layout. He has a parts list.
CW
This current thread illustrates that when buying components, like caps, you have to make a particular choice out of a variety of possibilities. As a novice I foresee the probability of several mistakes in the process and would like to avoid that.
Sequimite
Post by Sequimite »
drew wrote: ↑Tue Oct 26, 2021 8:26 pm Are you going to buy a board from Hoffman? If so, order as many of the components as you can from him, too.
Yes, I'm going to get the turret board from Hoffman. I'll take your suggestion and source as much as I can there.
drew
Post by drew »
Sequimite wrote: ↑Tue Oct 26, 2021 11:01 pm
Just make sure that whatever you’re going to use for a chassis will work with the 3.125” wide board material he uses.
