First amp build questions
Re: First amp build questions
The Hammond flat-pack transformers mentioned above are great for that purpose.
Being as there’s people here with sim skills -
Doesn’t C13 0.1uF DC blocking cap feeding the tonestack render the 0.1uF C15 bass cap redundant?
ie change C13 to 0.05uF and link across C15; does that give the same response?
Hopefully not too late, Mojotone carries a PT that may work nicely. 250v 120mA and 6.3v 1.5A
https://www.mojotone.com/GA-5-Reissue-R ... ransformer
Glenn
I solder better than I play.
I live in Hungary so ordering from Mojotone would be quite expensive, one of the Hammonds mentioned earlier will do the trick. Thanks for the recommendation though!GAStan wrote: ↑Sun Nov 05, 2023 3:01 am Hopefully not too late, Mojotone carries a PT that may work nicely. 250v 120mA and 6.3v 1.5A
I've managed to build the (pre)amp but there is a problem. Besides the nice sounding distorted guitar signal there is a high pitched squeal as well. Here are some things I managed to discover so far:
Gain at minimum: Gain at maximum: Does anybody know what might cause this?
- Knocking on the tubes with a wood stick has no effect
- Noise completely stops when the input is shorted
- The noise has harmonics (probably because of the high gain nature of the amp)
- Gain and mid pots modify the guitar signal as they should but they have some weird effects on the noise
- The noise goes from 2482 hz to 4205 hz as I turn the gain pot from min to max
- With the gain at max the guitar sound is no longer heard, just the squeal
- The mid pot at lower settings reduces the volume of the noise and at higher settings it increases the pitch a bit (but not the volume)
- Volume, high and bass pots work as they should
- Removing first tube has no effect
- Removing second tube reduces the noise slightly
- Connceting the grid of the last gain stage to ground slightly increases the pitch of the noise, connecting the other 3 grids to ground has no effect
- I can hear the squeal from the inside of the chassis very very very faintly, but I can't locate the exact source
Update: moving the input jack around with its wires changes the pitch of the squeal
If that's the case, i would improve all the grounds, resolder ground wires, sand connections at jacks and pots, clean with solvent and reassemble. That might kill your oscillation.
