Princeton Reverb Scratch build blocking dist
2pupwonder
Re: Princeton Reverb Scratch build blocking dist
Still probably need to do the output coupling caps and maybe input bypass cap reduction to clean up the remainder.
You don't actually need another filter cap. I only added separate ones because the cap can I had forced all the grounds to be together and I wanted to separate them. Node "C" on the board is effectively unused, so it's "just" a matter of moving that long reverb transformer under-board connection from node B to C (easier said than done!), and changing the 18K resistor (R69 on Hoffman's schematic) to 12k to keep the downstream voltages similar. I would also suggest changing R32 (Reverb driver cathode resistor) to 1.5k and adding a grid stopper to the reverb driver as discussed in that other thread. Those changes should keep it from overdriving.2pupwonder wrote: ↑Thu Aug 13, 2026 6:02 pm I will look into the reverb mod. Looks like would need an additional parallel filtering stage cap and some resistors.
2pupwonder
So I changed V1a & V1b cathode resistor bypass caps to 4.7uf. This definitely improved things, but still getting the nasty Harley idle distortion at higher settings. I also played with the bias, running it a bit hotter, and trying a new set of JJ 6v6's. I needed a new tip for my solder iron to change the coupling caps, which i have now.
next steps are:
- Test with a different speaker.
- Change the power section coupling caps - I have several values to try. .01 - .022 & .047uf
- Retest with V2 pulled
- Try a 5U4 rectifier and see if lower voltages help
- Change Reverb power - changing the Node C dropping resistor to 12K
- Change R32 to 1.5K - wondering if I should adjust the bypass cap as well.
- Add a 10k grid stopper to V2
Other ideas are to add 33k and 470k resistors on the PI Grid, then bring a 470K resistor from between them to the PI tail. I already have a 470Kgrid stopper here, but that's with the 1M PI grid lead in place.
I am also having some issues with the trem motorboating when it's off and the depth is on 10. This might be lead dress, but has anyone else had this?
Thanks!
2P
next steps are:
Thanks!
2P
