Dumble 102 ODS
The Quadratus
Re: Dumble 102 ODS
Post by The Quadratus »
martin manning wrote: ↑Mon Sep 14, 2026 2:21 pm I’m guessing the MV ground was sketchy from the start, and that was the root cause.
I thought that might be the case, but, that doesn't explain why I could control when it came on and off after I had reconnected the ground on the MV pot. Whatever it was, it's gone now 🤷
Now to try and sort out that transformer hum/vibration.
The Quadratus
Re: Dumble 102 ODS
nuke wrote: ↑Mon Sep 14, 2026 8:09 pm
The Quadratus wrote: ↑Mon Sep 14, 2026 1:33 pm Sorry, brother, I should have clarified. No noise, as in, no squeal or feedback. It is working absolutely perfectly.
I hate it when that happens! Makes me nervous when I think I forgot something, but it ain't broke. :lol:
Yeah, my comment could be taken either way. A good lesson on being succinct 😂
desertmouth90
Re: Dumble 102 ODS
Post by desertmouth90 »
My amp died the other night, my friend was using it haha... I think I set it up with the wrong impedance
The Quadratus
Re: Dumble 102 ODS
I just had a worrying thought. Am I mismarching what my amp wants to see in terms of speakers by running my 4ohm fender twin reverb speakers on the dumble? I built the 3rd gen 50w model and since it uses both the OT and PT from a fender twin, I just assumed that I could run the fender twin speakers.
Using a hammond 290fex for PT and a 1750w for OT with only 2 6l6gc tubes... I need a higher impedance load?
Last edited by The Quadratus on Tue Sep 15, 2026 10:01 am, edited 1 time in total.
The Quadratus
Re: Dumble 102 ODS
desertmouth90 wrote: ↑Tue Sep 15, 2026 8:05 am My amp died the other night, my friend was using it haha... I think I set it up with the wrong impedance
Oh dear, sorry to hear. What symptoms were reported?
Re: Dumble 102 ODS
The Quadratus wrote: ↑Tue Sep 15, 2026 8:35 am I just had a worrying thought. Am I mismarching what my amp wants to see in terms of speakers by running my 4ohm fender twin reverb speakers on the dumble? I built the 3rd gen 50w model and since it uses both the OT and PT from a fender twin, I just assumed that I could run the fender twin speakers.
1750W is listed at 2k primary with 4 ohm secondary. 2x 6L6 need a nominal 4k primary, so you should be running an 8 ohm speaker load.
The Quadratus
Re: Dumble 102 ODS
martin manning wrote: ↑Tue Sep 15, 2026 10:07 am
How on God's green earth do you know so much?
Re: Dumble 102 ODS
It just comes with experience. Lots of folks here could have answered the question.
desertmouth90
Re: Dumble 102 ODS
The Quadratus wrote: ↑Tue Sep 15, 2026 9:01 am
accidentally set the Impedance to 4ohm through a 16ohm cab
I reckon the valves have gone, but I hope its just a resistor or Fuse
The Quadratus
Re: Dumble 102 ODS
desertmouth90 wrote: ↑Tue Sep 15, 2026 1:50 pm
Let's hope the iron is all good too.
It almost seems criminal that a set of 4 tubes costs as much as an OT these days. Was watching some vids on when tubes were in production back in the day, they were practically giving them away.
nuke
Re: Dumble 102 ODS
Post by nuke »
The Quadratus wrote: ↑Tue Sep 15, 2026 12:28 pm
Make a lot of mistakes, break some things, bang head on wall, rinse lather repeat.
desertmouth90
Re: Dumble 102 ODS
I imagine your man Matrin Manning could have taught Dumble a thing or two haha
desertmouth90
Re: Dumble 102 ODS
The Quadratus wrote: ↑Tue Sep 15, 2026 9:37 pm
I believe it is the valves, upon visual inspection everything looks good, no fuses gone
always invest in a spare quad or duo of valves
desertmouth90
Re: Dumble 102 ODS
So, I have to finally admit I drilled a cabinet wrong, The chassis is too far back. despite me measuring 4 times and drilling once!
Do I just make the holes elongated? I think the ferrule washers will cover the gap.
Clive
Guy77
Re: Dumble 102 ODS
Post by Guy77 »
desertmouth90 wrote: ↑Fri Oct 09, 2026 1:07 pm So, I have to finally admit I drilled a cabinet wrong, The chassis is too far back. despite me measuring 4 times and drilling once!
Clive
If the washer doesnt cover it put a nice finishing machine screw in that hole and lock it from underneath with a nylon insert nut and washer, Then drill the correct hole.
Cheers
Guy
