Dumble 102 ODS testing
desertmouth90
Re: Dumble 102 ODS testing
Post by desertmouth90 »
timrobertson100 wrote: Fri May 02, 2025 8:50 pm Measures inductance, capacitance and resistance.
Mine lives in automatic mode - clip the leads on and it will work out what component it’s testing.
I got it originally as some very small capacitors have ambiguous labelling so it was impossible to be sure what you had.
Do you test individual components with it on the PCB for example?
desertmouth90
12B on the left and 12A on the right. You guys have saved me. I will be forever grateful!
Have a great weekend!
timrobertson100
Post by timrobertson100 »
desertmouth90 wrote: Fri May 02, 2025 8:54 pm
In many cases you can’t because other things in parallel influence the measurement. I use it for things I want to check when placing parts.
frusciante89
Post by frusciante89 »
Hello guys! Andrea here from AAE :) what this issue sorted? Let me know if there's any mislabeling in the layout!
Cheers from London
A
desertmouth90
The Voltages are really good now,
But there is no output when plugged into a speaker!
timrobertson100
Try plugging in to the effect return jack - it removes much of the circuit and can help to isolate the problem. Check wiring from there to the output.
desertmouth90
timrobertson100 wrote: Wed May 07, 2025 5:10 pm Try plugging in to the effect return jack - it removes much of the circuit and can help to isolate the problem. Check wiring from there to the output.
So I have been on holiday twice, injured my back in between, and now I have some flu or covid symptoms.
I have been thinking of rebuilding this 100w amp to make it up to the Aesthetics and functionality of the 50w build I have going on. The transformers for this will arrive soon.
for some reason I used ceramic sockets instead of Belkin Sockets for 8pin Tubes and all sorts of stuff I cut corners on with this build and I think I can do better.
what do you think? crack on and troubleshoot it, or rebuild with new chassis and faceplates?
Also I have a Tube Haul I found for £20 I will post pics of shortly
I would take the time to get this one working. You are probably not far away, and you will probably learn something. Then you can decide if you want to rebuild it or just go through it and tidy things up, maybe replacing some parts.
desertmouth90
martin manning wrote: Mon Jun 09, 2025 11:31 am I would take the time to get this one working. You are probably not far away, and you will probably learn something. Then you can decide if you want to rebuild it or just go through it and tidy things up, maybe replacing some parts.
Everything you said makes sense so I will follow it.
Please see pics for my Valve (Tube) Haul.
desertmouth90
B+ voltages are 455v in standby, out of standby they drop to 350ish. And there’s a hum. Not sure what’s causing this tbh.
Could be because they are unbiased?
Could be biased way too hot. In stand by, what is the voltage on power tube pin 5's?
desertmouth90
circa 360v. I have the Bias pot at max -V though
Edit: Sorry misread one moment
desertmouth90
martin manning wrote: Fri Jun 13, 2025 3:56 pm Could be biased way too hot. In stand by, what is the voltage on power tube pin 5's?
its -17.7v on each pin 5
-17V is much too high (not negative enough). You will need around -50V there.
Edit: above you had -50V available for biasing. Have you just not set the bias yet?
desertmouth90
martin manning wrote: Fri Jun 13, 2025 4:43 pm -17V is much too high (not negative enough). You will need around -50V there.
Bias not set yet.I tried that before I went away and ive completely forgetton how to do it tbh
