Dumble 102 ODS testing
Re: Dumble 102 ODS testing
For a start, dial it down to the most negative voltage on pin 5's, and you will need a way to measure the current flowing through the output tubes.
Bloody trim pot, I manhandled it abit and now I got -52vmartin manning wrote: ↑Fri Jun 13, 2025 4:43 pm -17V is much too high (not negative enough). You will need around -50V there.
Edit: above you had -50V available for biasing. Have you just not set the bias yet?
Weird
I was thinking of buying a bias meter, but I have a multimeter. Each Half winding has a resistance of 18ohmmartin manning wrote: ↑Fri Jun 13, 2025 5:14 pm For a start, dial it down to the most negative voltage on pin 5's, and you will need a way to measure the current flowing through the output tubes.
ok, you can use that. Did you have a look at the document here: https://ampgarage.com/forum/viewtopic.p ... 60#p474160 ? You will be measuring current as shown at C in the diagram.
Got an A in maths at school, that was the last time I used it. Will go through this with my sister (she’s an electrical engineer)martin manning wrote: ↑Fri Jun 13, 2025 5:51 pm ok, you can use that. Did you have a look at the document here: https://ampgarage.com/forum/viewtopic.p ... 60#p474160 ? You will be measuring current as shown at C in the diagram.
Well alright, great resource there! She should be able make sense of it, but I’m betting she hasn’t worked with valves before ;^)
No she has not, big gas turbines yes!martin manning wrote: ↑Sat Jun 14, 2025 12:54 pm Well alright, great resource there! She should be able make sense of it, but I’m betting she hasn’t worked with valves before ;^)
I will be able to work it out eventually.
It appears somewhere in the circuit the signal is getting pushed to ground.
Also appears that SPK2 Output is the main output for some reason… who only knows!?
Can you please post new pics, including a closeup of your output socket wiring?desertmouth90 wrote: ↑Sun Jun 15, 2025 9:48 am It appears somewhere in the circuit the signal is getting pushed to ground.
As requested, two 22uf filter caps were out of the damn circuit… a rookie error from… er… a rookie!timrobertson100 wrote: ↑Sun Jun 15, 2025 6:30 pmCan you please post new pics, including a closeup of your output socket wiring?desertmouth90 wrote: ↑Sun Jun 15, 2025 9:48 am It appears somewhere in the circuit the signal is getting pushed to ground.
FX loop and outputs changed to 12a from 12b. Will speak to mouser about this before my next order.
If you need anymore closeups of certain locations I can provide. Also tonight I will install 1R resistors to the Cathodes for biasing as apparently I forgot how to do maths.
Cheers
Clive
