Editable Overdrive Special Faceplate
- boldaslove6789
Though everybody could use a faceplate that could be modified to their own specific needs, made this last night. Its not exact as far as fonts go but its certainly close enough IMO.
I attached an editable Visio file and the .PDF ready to be printed. The face plate is scaled to 19.25" x 2.5".
You can go to FedEx/Kinco's and have them print it on "Coregated Plastic" for about $15 a faceplate and they're great quality. You can hit'em with some clear coat if you want a bit more glossiness too.
Hope this helps.
Hope this helps.
Greg D.C.
Can you dig it?
(NEW VIDS here!!) http://www.youtube.com/user/GDClarkProject
http://quinnamp.com/ http://www.prairiewoodguitars.com/
http://www.funkymunkpedals.com/
Can you dig it?
Re: Editable Overdrive Special Faceplate
Very nice, thanks. I'm running out of excuses not to do another build.
For some reason the Viso file has the text jumbled up.
On 100% it seems pretty small.
- boldaslove6789
Tom,
Sorry I didn't realize that the source text format would do that when used with a different PC that may not have these text. The outlined faceplate under the one that I made is a .CAD file made to scale that I used as a template. I don't know why its not to scale. The PDF should be fine though.
I got get rid of the "By Dumble" and left the "Overdrive Special", maybe that will be better use to those that want the logo but not the "Dumble" name.
If anybody wants the Faceplate tweaked to their needs just PM me and I'd be happy to change it to suit your needs
Here is that & the backplate also:
Last edited by boldaslove6789 on Tue Mar 15, 2011 11:56 pm, edited 1 time in total.
Greg D.C.
Can you dig it?
Can you dig it?
- boldaslove6789
I tried to fix the Keep Source formatting for the text.
Also, This faceplate (the back plate) is for the Ceriatone chassis.
The front panel may fit on the CE chassis but I can't say for sure until I get a .CAD file.
Tom,
Does this one work in Visio :
Tom,
Greg D.C.
Can you dig it?
Can you dig it?
this is excellent! thanks Greg. This one works just fine.
Greg; great work! Thnx.
I tried to open it in Visio but; I have to set the scale at page properties for 1:1, when doing this the text is staying as in the old scale(very small!)
What kind of font do you use? It looks great. 'The pdf and visio show up different in font, I like to use the one in your pdf.
Yep, still jumbled in the .vsd file.
What font is it?
The words Overdrive Special show as Pristina on my PC.
What font is it?
Strange....everything seems to line up just fine when i open it up in Visio. I'm using Visio 2007.
For the Preamp, Overdrive and Power Amp - the font shows Ariel.
For the FET and NOR - the font shows Agency FB.
For the Overdrive Special by Dumble - the font shows Pristina.
Rock, Bright, Mid and Jazz - DillenialUPC
Volume, Treble, Middle, Bass, Level, Ratio, Master, Presence - Agency FB
My software worked great the first time as well, nice job.
Mine too, seems like the issue is there.Structo wrote:Mine is 2003 Visio.
- boldaslove6789
PM me and I can give you Visio 07
Greg D.C.
Can you dig it?
Can you dig it?
That's kind of you; I just got started with visio. This is what I made of your drawing:boldaslove6789 wrote:PM me and I can give you Visio 07
- boldaslove6789
Thanks guys, glad I can contribute.
Greg D.C.
Can you dig it?
Can you dig it?
