need documents for: dumble small special 100w
buildafriend
Post by buildafriend »
I cant find any. I want to build one.
Well.. thats the end of that.
selloutrr
Re: need documents for: dumble small special 100w
Post by selloutrr »
try the dumble section
My Daughter Build Stone Henge
greenbottle
Small 100
Post by greenbottle »
Google Schematic Heaven. It comes under Webpix or a similar name.
Look under Dumble and find 60s dumble. there are 3 sheets.
Pre amp, power amp and power supply. This is suposed to be the small 100 cct
Goto www.roblivsey.com/dumble
Towards the bottom there are some pictures of a small 100.
you can go to USspeaker.com for bass speakers or to weber who also carries bass speakers. Weber also has a programme to calculate cabinet sizes but I don't know where you get the figures for weber speakers to plug into the programme. Usspeaker has that information associated with the speakers that they sell.
If you goto the "Dumble Dissusion" section of this forum and look for "3rd
gen again' He has a link to "EZYprint" which looks to be a good low volume screen print method.
Since the amp has 3x12a_7 valves and 4x6l6 valves you may be able to use a JTM45 size chassis. You can get an undrilled chassis of this size form MOJO and Turret boards.com who also sells turret board material, turrets and eyelets.
If you have any questions during your build the guys around here will bend over backwards to help you.
Have fun
Alan.
Dumble File Section has tons of info.
