Washers for Panel Switches
I was looking for washers for my panel mounted switched.
FYI for thoese that don't know the switch tread is 15/32-32.
Re: Washers for Panel Switches
It's hard to find something that looks kind of right. I've tried a 12mm washer, but most of what I can find locally is too wide. Thus, I've been using a .486 I.D. face washer(Carling switch) that I get from Watts Tube Audio.
TM
TM
Banzai has some nice washers:
http://www.banzaimusic.com/Nuts-and-Washers/?page=3
Must be some dealer in the US also who carries them.
-T
-T
- Milkmansound
they are almost impossible to find.
There are some shim washers out there that are close, but not perfect.
A friend of mine had a few thousand custom made for him and sells them here but not in small quantities:
http://www.missingwasher.com/
This is funny. Are any of us even sure what the OP is looking for?
switch lock washers are here http://angela.com/lockwashersforswitches.aspx
Outer beauty switch washers are at www.turretboards.com
- Milkmansound
haha nope!Gaz wrote:This is funny. Are any of us even sure what the OP is looking for?
I just like to shoot information like this:
http://www.youtube.com/watch?v=MP0yA3kTBn0
- leadfootdriver
Yeah, Watts (turret boards.com) has the washers for Carling switches.M Fowler wrote:switch lock washers are here http://angela.com/lockwashersforswitches.aspx
On a related note, who knows where I could get some isolating sleaves and or washers for a Switchcraft input jack? I'm going to try a multi star ground system.
You could try a "dress nut" search for those on Mouser or Digikey.
@ leadfootdriver:
"On a related note, who knows where I could get some isolating sleaves and or washers for a Switchcraft input jack?"
Switchcraft part numbers are: S1029 for the washer with shoulder and S1028 for it's counterpart without shoulder:
http://parts.digikey.com/1/parts/103859 ... s1029.html
http://search.digikey.com/us/en/cat/har ... 38?k=s1028
All the best.
All the best.
Horacio
Play in tune and B#!
- leadfootdriver
That's the ticket! Thanks!alvarezh wrote:@ leadfootdriver:
All the best.
That means making the hole in the chassis and front panel bigger (approx 11.4mm, I think) to tet the shoulder washer seated.leadfootdriver wrote:
For less hassle you can try the nylon-bushed Switchcraft jack socket that fits in the same 9.5mm hole as the metal socket that you already have - I think its part number is NL112A.
in the wilds of Borneo, and the vineyards of Bordeaux, Eskimo, Arapaho, move their bodies to and fro...
