nfb resistor question
I have a jtm45 with radio spares ot running a 8 ohm load I have a 27 k resistor in there now would a 47 k make the amp a little more gainy?
Re: nfb resistor question
Yes. For more fun and gain, leave the 27k fixed and insert a 100-250kB pot in series. Adjust to taste.
Stevem
Just note that you will be driving the output tubes harder so they will clip sooner, as such you may also want to bias them a tad cooler depending on what your ears tell ya!
As for the pot in series on the NFB, I prefer 100k lin or 250k log.
This way you have more control on the whole range.
So when a higher value NFB resistor is replaced making the amp a little more gainy, resulting in clipping sooner; will drive the output tubes harder ?Stevem wrote:Just note that you will be driving the output tubes harder so they will clip sooner, as such you may also want to bias them a tad cooler depending on what your ears tell ya!
I also see, if one had a high plate voltage, that biasing a little cooler will prolong tube life, but more importantly dial in a tone that one is satisfied with.
If one has a 47k upped to a 100k, then I would be conscious of biasing a tad under (to taste of course) and have the option of the 3 taps. (something like that ?)
"What does that do ?"
- gui_tarzan
Do you have pics of the outside and inside? I just finished updating a '64 JTM45 and you're right, it does need a little more gain than stock but boy are they sweet.
--Jim
First thing I do on a 45 is swap a 470k divider pair in place of the 270ks before V2. Mostly about bringing the 'chest' out a little.
TimmyP1955
Doesn't that make the bright input even brighter?Reeltarded wrote:First thing I do on a 45 is swap a 470k divider pair in place of the 270ks before V2. Mostly about bringing the 'chest' out a little.
yes, 22k + 250k pot into 16ohms secondaryColossal wrote:Yes. For more fun and gain, leave the 27k fixed and insert a 100-250kB pot in series. Adjust to taste.
This is a real 45, not a reissue or clone? +1 Please post good picts.
