I want to solve this last little bug-a-boo in this amp and want to try this but it doesn't seen right. If I ground the junction he mentions I'd be grounding the grid leak bias, the tube would be in runaway when nothing is plugged into either side. In fact any way I try to ground the grid on a grid leak amp I'm be losing the bias, no? What am I missing, will the way it's described above actually work? What is the point of a value 2.2k as a stopper? Just to have the lowest value to ground and still act as a stopper? IOW why not 10K or 33K, or 1K for that matter?A typical input scheme on old Supros is a 47K to 100K resistor right off the jack hot, into a cap that varied from .01 to .05. [As a side note, there really is no need to go larger than .02 here, and doing so allows for hotter signals to "swamp" the input grid just like an oversized coupling cap, leading to what sounds like blocking distortion.] The grid leak, usually 6.8M, follows the cap, and then there was usually a 2.2K soldered from that junction right to the tube pin. To allow the shorting jack to work effectively, I've found it best to run a short wire from the ground 'switch' on the jack to the junction of the cap, grid leak and 2.2K resistor. this quiets it down a lot when nothing is plugged in because it allows the shorting jack to effectively short to ground, or within 2.2K of ground, as the jack is intended. EFK 08-20-2012, 11:25 PM #10
If not anyone got a proper work-around to shorting the grid leak bias using just the jacks when unplugged? I guess I can not worry about it, Fender never did, but it'd be nice to get this amp buttoned up 100%.
Also what is the difference to varying the grid leak resistors say from 4.7 to 5.6, 6.8 10M? Or it doesn't matter here as long as a charge is built up.
