5V heaters high - dropping needed?
Hey.
I just finished putting together a nice Asteroid. (still trying to come up with a simple name... wondering about Halley).
Anyways, the 6,3V heaters were too high, but a couple of 0,1R/5W'ers brought them down precisely to 6,3V.
However, the 5V's are high too, sitting about 5,95V.
I wonder if this is a bit problematic like the 6.3V heaters, and whether I should bring them down in similar way?
Regards
Anders
Regards
Anders
Re: 5V heaters high - dropping needed?
It's a good idea for long tube life to run power tubes at just their specified heater voltage.
The story for preamp tubes is complicated.
"For every complex problem there is an answer that is clear, simple, and wrong"
H. L. Mencken
H. L. Mencken
Stevem
The accepted range for heaters is + or - 10%, and your at + 16%.
You will also have somewhat higher V+ due to this which may or may not be a issue dependant on the excess voltage rating you may have on your power supply filters.
A increase in V+ may also kick your preamp gain structure up more than you where shooting for .
If you have resistors on hand you can bring it down, of just resign yourself to having 6% less rectifier life, which to me really does not sound too bad, especially if you are running a 5U4 recto with its massive cathode and plate structure!
Or use a 6V rectifier tube: 6AX5GT, 6BY5GA are octal base - check the pin-outs
Stevem
Just note that the 125 ma rating of a 6AX5 is barely good enough for running 2 6v6 tubes and 4 or 5 ax7s.
I'll go ahead and state the heresy - two silicon diodes and a power resistor make a very convincing replacement for a tube rectifier. Better yet, this setup doesn't care if it's heater voltage is 5V or 50V.
H. L. Mencken
H. L. Mencken
Stevem
Run both!
With this you will still get some good sag , and if the recto ever blows you can replace the fuse , yank out the blown recto and Just play on!
Indeed. But if the 5V winding is rated for 3A, you run run two 6AX5 in parallel.
Stevem
Lol, oh ok!
- billyz
What about a bucking transformer. Solve all your high voltage issues.
