240v Pilot Light With 120v
RockinRocket
I have a really cool NOS pilot light I want to use but its 240v. I could change the bulb with some effort but what would happen, is it safe if I run 120v into it instead? LOL probably a silly question but I simply just dont know!
- Malcolm Irving
Re: 240v Pilot Light With 120v
It would be safe enough, but would only light up very dim.
Maybe it will be perfect. I usually think the damn pilot lights are too bright.
RockinRocket
Guess ill have to hook it up and see!
Yep, hook it up and see.
What will actually happen depends on the bulb technology. If it's incandescent, it will get much dimmer and the color will shift towards red - a lot. If it's neon, it will be about the same color, but much dimmer, as neons "arc over" at 70-100V across them and emit light while conducting, the current (and resulting brightness) being limited by a series resistor. The resistors for 240 are much larger than for 120, reflecting the difference in voltage. But the internal emissions have the same spectrum.
"For every complex problem there is an answer that is clear, simple, and wrong"
H. L. Mencken
H. L. Mencken
