Paging Andy Fuchs/Associates
jaysg
Post by jaysg »
I have a ~2008 100 ODS w/reverb head in. SN 189x, inked on HRM.1 It is very noisy on the OD channel. To be clear, it can't be used live. Clean is just fine: B+ is 505V, and the biases all read between 36 and 38mV, assuming a 1 ohm resistor...green things.
I have my own non-HRM modded Fender and it is significantly quieter, so I'm looking for some help. V1 & V2 are some sort of EH. V3 & V4 are Ruby. Output tubes are TAD. I have swapped all tubes with known good ones. Functionality is all as expected...no different on Footswitch vs. panel switches.
Please contact me and I can certainly send pictures if needed.
pompeiisneaks
Site Admin
Re: Paging Andy Fuchs/Associates
Post by pompeiisneaks »
I've deleted a few of what looked like duplicates, but who is Greg?
Colossal
Post by Colossal »
pompeiisneaks wrote: ↑Tue Aug 13, 2019 9:16 pm I've deleted a few of what looked like duplicates, but who is Greg?
He is/was a moderator (HeeBGB)
pompeiisneaks
Site Admin
Colossal wrote: ↑Tue Aug 13, 2019 11:44 pm
Oh gotcha, yeah technically he still 'is' but hasn't been moderating in forever. I do see, though, that he's been active recently!?
jaysg
Post by jaysg »
I bought a Sammi from Greg once. I'm not very active here, but no one from Fuchs has replied, so I would love some help with this amp. The guy has been using the Clean channel only and I'm not sure where to start with the noise on the OD, since the tubes seem to check out. My experience is that I'm rarely the first guy to run into whatever problem there is with fill-in-the-blank.
[edit] See below...yes, that is where I contacted them
pompeiisneaks
Site Admin
jaysg wrote: ↑Wed Aug 14, 2019 1:52 am I bought a Sammi from Greg once. I'm not very active here, but no one from Fuchs has replied, so I would love some help with this amp. The guy has been using the Clean channel only and I'm not sure where to start with the noise on the OD, since the tubes seem to check out. My experience is that I'm rarely the first guy to run into whatever problem there is with fill-in-the-blank.
If you can post some gut shots, we may be able to assist. Andy is on the forums from time to time as well, he's more frequent on facebook if you wanted to try them there. Have you tried their Contact Us link? http://fuchsaudiotechnology.com/contact-us/
jaysg
Post by jaysg »
There are no...sigh...black spots. I do appreciate when a product has blown a part and you can see it.
I have swapped with good tubes and read off the B+ (505) and stable bias currents (36 to 38mA).
Oh...V1 and V2 are hiding in the front under the green pcb for inputs.
pompeiisneaks
Site Admin
Yeah I don't see anything obviously wrong either. Have you tried chopsticking the amp with the OD engaged to see if something specific makes it worse or better? Could be a component has just gone out, Coupling caps can sometimes go out and go microphonic, touching them will make this pretty apparent.
FUCHSAUDIO
Post by FUCHSAUDIO »
Why not e mail tech support directly ? Pictures of the board and such may help. No reason for it to be any more or less noisy then any other d style. Is there a FET by-chance on the board ?
jaysg
Post by jaysg »
Have done twice.
FUCHSAUDIO
Not sure why, but we have not seen your e mails...try info or sales@ addresses plz. Maybe a spam filter clipped it.
stelligan
Post by stelligan »
sexy guts :D
jaysg
Post by jaysg »
Tied up, I will try again. Hopefully, you'll see it come Monday.
[edit] Mail away on Sunday pm.
