LND150 Tremolo?
LND150 Tremolo?
Hi,
I'm currently working out a circuit for a cathode biased EL84 amp and realized I have not one single amp with a tremolo built in.
As the oscillator is not part of the signal I think it's unnecessary to waste a triode for it. There is almost nothing to find about simple LND150 oscillators and I wonder why?
Has someone done this before and can recommend a simple circuit?
Thanks a lot!
Thanks a lot!
Re: LND150 Tremolo?
More excellent reading: http://www.geofex.com/Article_Folders/m ... tfolly.htm
This includes the famous MOSFET B+ reducer that I've used many times.
Re: LND150 Tremolo?
All written up by our very own R.G.xtian wrote: ↑Sun Mar 22, 2020 4:29 pm More excellent reading: http://www.geofex.com/Article_Folders/m ... tfolly.htm
Re: LND150 Tremolo?
Thanks for the fast reply!
I see, that's quite simple but does require a LDR. I have pedals that do basically the same and I would like to follow a more traditional approach where the tremolo is connected to the cathode of a gain stage for bias wiggle that can't be done with a pedal.
Something like a Vibro Champ or the Kalamazoo Model 2:
http://www.rru.com/~meo/Guitar/Amps/Kal ... 2Schem.gif
Re: LND150 Tremolo?
You can do that with an LND150.
Re: LND150 Tremolo?
Is there anything about tremolo in the geofex link?
- statorvane
Re: LND150 Tremolo?
I think this is the one you are looking for: http://www.geofex.com/Article_Folders/s ... remolo.htm
Re: LND150 Tremolo?
The Vibe Champ SS Vibrato looks good as well but isn't it missing diodes?
Is that circuit verified?
The Supro 1690T has a simple circuit too which could be done with a LND150. Not sure about the Intensity control as variable plate resistor..
Re: LND150 Tremolo?
Ah, I had the optional protection diodes in mind but they are only useful at large input signals.martin manning wrote: ↑Mon Mar 23, 2020 3:09 pmWhy do you say that?
I think you could do a simple LND150 LFO, and couple that in with the cathode of a preamp stage ala the Kalamazoo Model 2 above.
You mean something like this? I like the simplicity of that circuit but eventually miss a control for intensity.
Re: LND150 Tremolo?
The LND150 LFO probably won't oscillate with a bias that high.
Re: LND150 Tremolo?
Something like this. You will probably get some noise on the intensity pot, but it is very effective this way, from completely off to very choppy.
Re: LND150 Tremolo?
Thank you very much, Martin.
This one indeed looks very simple!
How about cathode bypass caps parallel to R3?
Also I'm thinking about global feedback which had to be fed back to the cathode of that gain stage just like in a Vibro Champ.
You would rather insert the LFO after the cathode resistor?
Here's a reference:
Here's a reference:
Re: LND150 Tremolo?
For that arrangement I would add another FET as a source follower, exactly as in the Vibro-Champ.
