Mixing Channels with Virtual Earth?
Mr. Lime
Post by Mr. Lime »
Thinking about different ways to blend clean and dirty channels I'm wondering if a virtual earth summing triode is an good option?
The gain stage with local feedback could serve as a cathode follower /FX Loop send.
Problem could be the tone stack of the dirty channel but it also could pad the signal down near to the level of the clean channel.
Am I on the right tracks with the mixing resistors or what else is to consider?
Thanks a lot!
luix
Re: Mixing Channels with Virtual Earth?
Post by luix »
Virtually the 470k resistors are high enough to isolate the two circuits from each other, but I think that the tonestack of the upper circuit will also act in the other channel, maybe just a little bit but can be subtle and annoying.
The best solution is to buffer the upper channel.
The only way to be sure is trying it :D
Always install a humdinger!
pdf64
Post by pdf64 »
luix wrote: ↑Tue Jan 12, 2021 1:19 pm Virtually the 470k resistors are high enough to isolate the two circuits from each other, but I think that the tonestack of the upper circuit will also act in the other channel, maybe just a little bit but can be subtle and annoying.
That may well happen with a regular passive mixer.
But surely the virtual earth would act to eliminate that? That’s kinda its raison d’etre :)
TUBEDUDE
Post by TUBEDUDE »
You could reconfigure as an anode mixer.
Mr. Lime
Post by Mr. Lime »
An anode mixer would cause phase issues and the low output impedance woulf be gone.
I‘m more after a cathode follower with double function..
luix
Post by luix »
TUBEDUDE wrote: ↑Wed Jan 13, 2021 2:36 am You could reconfigure as an anode mixer.
This is a good idea, unless you have arranged the circuit in that way for some "sound" related reason, the anode mixer will be a better solution, I've successfully used with JFET transistors and I think that also with tubes will work.
Mr. Lime
Post by Mr. Lime »
I once tried an anode mixer and it didn't worked for me. I married a two stage with a four stage channel in front of a shared tone stack but I had squealing problems.
Anyway, an anode mixer isn't an option here and not of my interest.
