LARGE 6V6??
LARGE 6V6??
G'day.... Has anyone ever seen 6V6's that are this tall (see pic)....? The amp's maker, but not the previous owner, said the amp performed well with them, & they could be Chinese oddballs.... They're totally unmarked, and the one on the far right, or on top, is my standard sized Tung-Sol 6V6....
many thanks ॐ
many thanks ॐ
Re: LARGE 6V6??
More then likely Russian made I would say.
The Chinese would never waste money / send profit down the drain by using extra glass to make a tube.
Re: LARGE 6V6??
If they are totally unmarked, what would make you think that they are 6V6?zozoe wrote: ↑Thu Aug 10, 2023 3:39 pm G'day.... Has anyone ever seen 6V6's that are this tall (see pic)....? The amp's maker, but not the previous owner, said the amp performed well with them, & they could be Chinese oddballs.... They're totally unmarked, and the one on the far right, or on top, is my standard sized Tung-Sol 6V6....
Re: LARGE 6V6??
Try measuring how much heater current they draw. My guess is that it’ll be more like 0.9A each than 0.45A
Re: LARGE 6V6??
not russian.. russian version is 6P6S, short bottle black glass
Re: LARGE 6V6??
[/quote]
[/quote]
ONLY because it's what the amp calls for, and that I bought it from the builder, RC Davis, but he wasn't the last owner... He said it works well, but I wanna stay on the side of another owner's errors, and give it what's truly called for..... ॐ
[/quote]
Re: LARGE 6V6??
Looks like a Russian 6P3S (6L6 derivate)
Re: LARGE 6V6??
I'm gonna ditch them for something I'm certain about...
Thnx all!!
Thnx all!!
Re: LARGE 6V6??
some pics from top will help.. can be yes 6P3S, this is thenclose to 6L6 (not GC version) or 5881 tube - 19W dissipation, slight overkill for 6V6
Re: LARGE 6V6??
RCA set up a valve production facility and provided training for the Soviets in 1937. So rather than being a derivative / reverse engineered 6L6, the 6P3S (or at least what became the 6P3S) may have been a fully licensed / approved 6L6
https://en.m.wikipedia.org/wiki/Russian ... signations
Re: LARGE 6V6??
They would then be a 6L6B and the in line exit of all the internal leads limits the voltage that can be placed on them without arcing.
